SFTP connection timeout issue
Rahul Johny February 7, 2021 edited
I have configured the pipeline as below.
- pipe: atlassian/sftp-deploy:0.5.7
variables:
USER: 'oracle'
SERVER: '120.139.9.213'
REMOTE_PATH: "/home/oracle/testDeploy"
LOCAL_PATH: '$BITBUCKET_CLONE_DIR/release_package/*'
PASSWORD: 'xxxxxx'
DEBUG: 'true'
EXTRA_ARGS: '-P 2232'
#EXTRA_ARGS: ["-P", "2232"]
I am able to SFTP using winscp to the host with password
Please find the logs below.
--env=BITBUCKET_REPO_OWNER="$BITBUCKET_REPO_OWNER" \ --env=BITBUCKET_REPO_IS_PRIVATE="$BITBUCKET_REPO_IS_PRIVATE" \ --env=BITBUCKET_WORKSPACE="$BITBUCKET_WORKSPACE" \ --env=BITBUCKET_REPO_OWNER_UUID="$BITBUCKET_REPO_OWNER_UUID" \ --env=BITBUCKET_STEP_RUN_NUMBER="$BITBUCKET_STEP_RUN_NUMBER" \ --env=BITBUCKET_BUILD_NUMBER="$BITBUCKET_BUILD_NUMBER" \ --env=BITBUCKET_BRANCH="$BITBUCKET_BRANCH" \ --env=BITBUCKET_GIT_SSH_ORIGIN="$BITBUCKET_GIT_SSH_ORIGIN" \ --env=BITBUCKET_PIPELINE_UUID="$BITBUCKET_PIPELINE_UUID" \ --env=BITBUCKET_COMMIT="$BITBUCKET_COMMIT" \ --env=BITBUCKET_REPO_UUID="$BITBUCKET_REPO_UUID" \ --env=BITBUCKET_CLONE_DIR="$BITBUCKET_CLONE_DIR" \ --env=BITBUCKET_PROJECT_KEY="$BITBUCKET_PROJECT_KEY" \ --env=PIPELINES_JWT_TOKEN="$PIPELINES_JWT_TOKEN" \ --env=BITBUCKET_STEP_UUID="$BITBUCKET_STEP_UUID" \ --env=BITBUCKET_DOCKER_HOST_INTERNAL="$BITBUCKET_DOCKER_HOST_INTERNAL" \ --env=DOCKER_HOST="tcp://host.docker.internal:2375" \ --env=BITBUCKET_PIPE_SHARED_STORAGE_DIR="/opt/atlassian/pipelines/agent/build/.bitbucket/pipelines/generated/pipeline/pipes" \ --env=BITBUCKET_PIPE_STORAGE_DIR="/opt/atlassian/pipelines/agent/build/.bitbucket/pipelines/generated/pipeline/pipes/atlassian/sftp-deploy" \ --env=DEBUG="true" \ --env=EXTRA_ARGS="-P 2232" \ --env=LOCAL_PATH="$BITBUCKET_CLONE_DIR/release_package/*" \ --env=PASSWORD="" \ --env=REMOTE_PATH="/home/oracle/testDeploy" \ --env=SERVER="120.139.9.213" \ --env=USER="oracle" \ --add-host="host.docker.internal:$BITBUCKET_DOCKER_HOST_INTERNAL" \ bitbucketpipelines/sftp-deploy:0.5.7Unable to find image 'bitbucketpipelines/sftp-deploy:0.5.7' locally0.5.7: Pulling from bitbucketpipelines/sftp-deploy31603596830f: Pulling fs layer5223754e1462: Pulling fs layere082d8591f92: Pulling fs layer11c53ae80555: Pulling fs layer3dc58ede5d22: Pulling fs layer3dc58ede5d22: Waiting11c53ae80555: Waitinge082d8591f92: Verifying Checksume082d8591f92: Download complete31603596830f: Verifying Checksum31603596830f: Download complete5223754e1462: Verifying Checksum5223754e1462: Download complete11c53ae80555: Verifying Checksum11c53ae80555: Download complete31603596830f: Pull complete3dc58ede5d22: Verifying Checksum3dc58ede5d22: Download complete5223754e1462: Pull completee082d8591f92: Pull complete11c53ae80555: Pull complete3dc58ede5d22: Pull completeDigest: sha256:4767af0e7706ae28565f2903e28a7747e098284eb0b6324430ada075469c4023Status: Downloaded newer image for bitbucketpipelines/sftp-deploy:0.5.7+ SFTP_DEBUG_ARGS=-v+ [[ -z  ]]+ info 'Using PASSWORD.'INFO: Enabling debug mode.INFO: Using PASSWORD.+ echo -e '\e[36mINFO: Using PASSWORD.\e[0m'+ setup_ssh_dir+ INJECTED_SSH_CONFIG_DIR=/opt/atlassian/pipelines/agent/ssh+ IDENTITY_FILE=/opt/atlassian/pipelines/agent/ssh/id_rsa_tmp+ KNOWN_HOSTS_FILE=/opt/atlassian/pipelines/agent/ssh/known_hosts+ mkdir -p /root/.ssh+ touch /root/.ssh/authorized_keys+ [[ -z ]]+ '[' '!' -f /opt/atlassian/pipelines/agent/ssh/known_hosts ']'+ cat /opt/atlassian/pipelines/agent/ssh/known_hosts+ '[' -f /root/.ssh/config ']'+ [[ -z  ]]+ chmod -R go-rwx /root/.ssh/+ run_pipe+ info 'Starting SFTP deployment to 120.139.9.213:/home/oracle/testDeploy...'+ echo -e '\e[36mINFO: Starting SFTP deployment to 120.139.9.213:/home/oracle/testDeploy...\e[0m'+ set +e+ [[ -z 3 ]]INFO: Starting SFTP deployment to 120.139.9.213:/home/oracle/testDeploy...+ debug Executing echo '"mput' '/opt/atlassian/pipelines/agent/build/release_package/*"' '|' sshpass -p ######@123 sftp -o PubkeyAuthentication=no -rp -v -P 2232 oracle@120.139.9.213:/home/oracle/testDeploy+ [[ true == \t\r\u\e ]]+ echo -e '\e[37mDEBUG: Executing echo "mput /opt/atlassian/pipelines/agent/build/release_package/*" | sshpass -p  sftp -o PubkeyAuthentication=no -rp -v -P 2232 oracle@120.139.9.213:/home/oracle/testDeploy\e[0m'DEBUG: Executing echo "mput /opt/atlassian/pipelines/agent/build/release_package/*" | sshpass -p #######@123 sftp -o PubkeyAuthentication=no -rp -v -P 2232 oracle@120.139.9.213:/home/oracle/testDeploy+ echo 'mput /opt/atlassian/pipelines/agent/build/release_package/*'+ sshpass -p  sftp -o PubkeyAuthentication=no -rp -v -P 2232 oracle@120.139.9.213:/home/oracle/testDeployOpenSSH_7.9p1, OpenSSL 1.1.1g 21 Apr 2020debug1: Reading configuration data /etc/ssh/ssh_configdebug1: Connecting to 120.139.9.213 [120.139.9.213] port 2232.debug1: connect to address 120.139.9.213 port 2232: Operation timed outssh: connect to host 120.139.9.213 port 2232: Operation timed outConnection closed+ STATUS=255+ set -e
Oleksandr Kyrdan
February 7, 2021
Hi @Rahul Johny ,
Thank you for your question!
IMPORTANT!
Please, try to avoid post debugged output with your sensitive data.
We're highly recommend to change your service password as soon as possible.
Is provided port 2232 accessible?
yes its accessible. when connecting via WinSCP
@Oleksandr Kyrdan  yes the port is accessible
ktomk
February 9, 2021
Connection timed out. Perhaps the remote system is not reachable? For example behind a Firewall?
What are the IP addresses to configure a corporate firewall?
atlassian, state of devex 2025, developer experience, devex report, developer productivity, ai in software development, engineering challenges, team collaboration, internal developer platform, time management, developer survey, space framework
Atlassian State of Developer Experience Report 2025
AI is reshaping the dev experience, with faster builds but adding more friction. See what 3,500 developers and managers say about productivity, tools, and team alignment in Atlassian’s State of Developer Experience report 2025.
Explore the report
