SSH connection fails in Bitbucket pipeline
Robert-Paul
October 27, 2025
Hi everyone,
I’m stuck with the following Bitbucket pipeline YAML script. When the runner tries to connect to another server via SSH, it fails, even though the private/public key pair is correctly set up. From the machine running the runner, the SSH connection works fine, but not from within the runner process itself
+ ssh -o StrictHostKeyChecking=no $SSH_USER:$SSH_HOST << EOF
echo 'Run deploy...'
docker stop xyz-website || true
docker rm xyz-website || true
docker run -d \
--name xyz-website \
-p 80:5010 \
--restart always \
echo 'Deployment finished.'
EOF
And here’s the error output:
Pseudo-terminal will not be allocated because stdin is not a terminal.
Warning: Permanently added '<HOST>,<IP>' (ECDSA) to the list of known hosts.
ssh_askpass: exec(/usr/bin/ssh-askpass): No such file or directory
Permission denied, please try again.
It seems like SSH is falling back to a password prompt when the public/private key authentication fails, but since there’s no ssh-askpass available, the connection breaks.
Has anyone run into this before? Or is there something I’m missing in how Bitbucket handles SSH keys inside the runner process?
Product Admin Site Admin
