Self Hosted Runner in Kubernetes Cluster Failing Using atlassian/kubectl-run Pipe
Marv Agabi September 30, 2023
I am trying to use a self hosted runner to deploy application changes to a kuberentes cluster.
The runner is the linux docker runner running inside of a kuberentes cluster. This was accomplished using this guide.
When I try to run a simple pipeline to 'get pods -A' the pipeline fails with the errors below.
I initially though this was because the pod running the runner and docker in docker containers didn't have a reference for the devk8m00 server specificed in the kubeconfig. So I edited the pod to have a host file entry pointing to the k8s cluster server LB VIP for devk8sm00.
Am I missing something, how can I get this runner running inside of the k8s cluster to be able to run commands to it?
0b57ecec8b3f: Pull complete
dc70d1c0613d: Pull complete
Digest: sha256:2c607a7cfb7cf0f4fd7bf95f9d70fdf910b5f2042ffe5a9576da8a90e5368b09
Status: Downloaded newer image for bitbucketpipelines/kubectl-run:3.8.0
INFO: Configuring kubeconfig...
E0930 21:16:43.341822 7 memcache.go:265] couldn't get current server API group list: Get "https://devk8sm00:6443/api?timeout=32s": dial tcp: lookup devk8sm00 on 10.96.0.10:53: server misbehaving
E0930 21:16:43.347571 7 memcache.go:265] couldn't get current server API group list: Get "https://devk8sm00:6443/api?timeout=32s": dial tcp: lookup devk8sm00 on 10.96.0.10:53: server misbehaving
E0930 21:16:43.353729 7 memcache.go:265] couldn't get current server API group list: Get "https://devk8sm00:6443/api?timeout=32s": dial tcp: lookup devk8sm00 on 10.96.0.10:53: server misbehaving
E0930 21:16:43.358067 7 memcache.go:265] couldn't get current server API group list: Get "https://devk8sm00:6443/api?timeout=32s": dial tcp: lookup devk8sm00 on 10.96.0.10:53: server misbehaving
E0930 21:16:43.362971 7 memcache.go:265] couldn't get current server API group list: Get "https://devk8sm00:6443/api?timeout=32s": dial tcp: lookup devk8sm00 on 10.96.0.10:53: server misbehaving
Unable to connect to the server: dial tcp: lookup devk8sm00 on 10.96.0.10:53: server misbehaving
✖ kubectl get pods -A failed.
Marv Agabi October 1, 2023
Figured it out, it was a DNS issue. devk8sm00 is the load balancer vip for my cluster which did not have a dns entry so the pod couldn't resolve it. Correcting that fixed the issue and I'm up and running now.
Upcoming Bitbucket Events
