Self hosted bitbucket runner 'docker command not found'
Charlie Davies
We have 3 self hosted runners which run fine for a while until one day our pipelines start to fail with 'docker command not found'. We then have to delete the runners and re-add new ones after that everything works as expected.
Anyone have any experience with this?
We do run watchtower against these runner images to keep them up to date. Could this be causing an issue?
Thanks.
Theodora Boudale
February 14, 2024
Hi Charlie,
Are these Linux Docker runners?
If so, can you check the following knowledge base article?
It has details about a possible cause for this error and the steps you can take to resolve, if you are running into the same issue.
Theodora
Charlie Davies
Hi Theodora,
Yes that is the problem. Thank you for pointing me in the direction of the answer.
Kind Regards,
Charlie
Like • 2 people like this
Theodora Boudale
February 16, 2024
Hi Charlie,
You are very welcome, it's good to hear that this helped. Please feel free to reach out if you ever need anything else!
Theodora
Like • Sabine Mayer likes this
