Sending reports automatically post build completion irrespective of failed or passed
Sandeep.Dash
I have a extent report which generates dynamically every time the code automation suite runs. How do i make sure this report goes out to stakeholders once the build is completed in the pipeline. Please suggest some ways through yml file.
Depstan Thankachan Xavier March 28, 2023
Thanks @Sandeep.Dash , Will checkout the same as advised.
Sandeep.Dash
March 9, 2023 edited
I used a third party tool  and passed its api key, that allowed my code to interact with outlook and send mail across. This worked with me very well both from local and pipeline. I guess there is nothing we can do from yml file.
If not sendgrid check with company team if they are using any other third part tool which can be integrated with your code libs to send mails across automatically.
Sandeep
Depstan Thankachan Xavier March 8, 2023
any solutions to share @Sandeep.Dash
deepa
March 2, 2023
Hi Sandeep, did u find out a way? Actually I'm facing same, so can you help me how u have handled
Upcoming Bitbucket Events
