Serverless deploy with plugins and dockerpip
Aakash Shah
September 9, 2022 edited
I am unable to figure out why the serverless deploy is not going through.
This is the bibucket-pipeline.yml
options
docker: true
definitions:
services:
docker:
memory: 3072
pipelines:
branches:
dev:
- step:
services:
- docker
script:
- cp config.dev.ini config.ini
- pipe: atlassian/serverless-deploy:1.2.0
variables:
AWS_ACCESS_KEY_ID: $AWS_ACCESS_KEY_ID_DEV
AWS_SECRET_ACCESS_KEY: $AWS_SECRET_ACCESS_KEY_DEV
PRE_EXECUTION_SCRIPT: "my-script.sh"
 EXTRA_ARGS: "--verbose"
Error during serverless deploy
Installing requirements from "/root/.cache/serverless-python-requirements/1f8875b144ca0ef6448bc54adcda2143dac724167f52c31feeb3279ccc4a6bc1_x86_64_slspyc/requirements.txt"
Docker Image: lambci/lambda:build-python3.8
Using download cache directory /root/.cache/serverless-python-requirements/downloadCacheslspyc
Running docker run --rm -v /root/.cache/serverless-python-requirements/1f8875b144ca0ef6448bc54adcda2143dac724167f52c31feeb3279ccc4a6bc1_x86_64_slspyc\:/var/task\:z -v /root/.cache/serverless-python-requirements/downloadCacheslspyc\:/var/useDownloadCache\:z lambci/lambda\:build-python3.8 /bin/sh -c 'chown -R 0\\:0 /var/useDownloadCache && python3 -m pip install -t /var/task/ -r /var/task/requirements.txt --cache-dir /var/useDownloadCache && chown -R 0\\:0 /var/task && chown -R 0\\:0 /var/useDownloadCache && find /var/task -name \\*.so -exec strip \\{\\} \\;'...
Stdout:
Stderr: docker: Error response from daemon: authorization denied by plugin pipelines: -v only supports $BITBUCKET_CLONE_DIR and its subdirectories.
See 'docker run --help'.
Environment: linux, node 16.17.0, framework 3.22.0 (local) 3.22.0v (global), plugin 6.2.2, SDK 4.3.2
Credentials: Local, environment variables
Docs: docs.serverless.com
Support: forum.serverless.com
Bugs: github.com/serverless/serverless/issues
Error:
Error: `docker run --rm -v /root/.cache/serverless-python-requirements/1f8875b144ca0ef6448bc54adcda2143dac724167f52c31feeb3279ccc4a6bc1_x86_64_slspyc:/var/task:z -v /root/.cache/serverless-python-requirements/downloadCacheslspyc:/var/useDownloadCache:z lambci/lambda:build-python3.8 /bin/sh -c chown -R 0\:0 /var/useDownloadCache && python3 -m pip install -t /var/task/ -r /var/task/requirements.txt --cache-dir /var/useDownloadCache && chown -R 0\:0 /var/task && chown -R 0\:0 /var/useDownloadCache && find /var/task -name \*.so -exec strip \{\} \;` Exited with code 125
at ChildProcess.<anonymous> (/opt/atlassian/pipelines/agent/build/node_modules/child-process-ext/spawn.js:38:8)
at ChildProcess.emit (node:events:513:28)
at ChildProcess.emit (node:domain:489:12)
at maybeClose (node:internal/child_process:1093:16)
at Process.ChildProcess._handle.onexit (node:internal/child_process:302:5)
serverless.yml
custom:
pythonRequirements:
pythonBin: python3
dockerizePip: true
slim: true
useDownloadCache: true
useStaticCache: true
Any help would be very much appreciated. It loks like its because of useDownloadCache or this could be it - $BITBUCKET_CLONE_DIR and its subdirectories.
Igor Stoyanov
September 16, 2022
@Aakash Shah hi. Could your share also your pre-execution script?
Regards, Igor
Syahrul
September 11, 2022
Hey @Aakash Shah
Welcome to the community.
I believe the error is related to the execution permission of the script. As mentioned in the documentation here if you pass a hook script, the script should have at least read and execution permission.
I would suggest changing the script permission with the following step:
  - chmod 005 my-script.sh
    variables:
      PRE_EXECUTION_SCRIPT: '.my-script.sh'
Syahrul
