I'm trying to install smart mirroring but get some problems.
Let me describe the scenario
Bitbucket primary: https://haproxy.com.tw
Bitbucket mirror: https://haproxy.backup.com
These Bitbucket use Haproxy, when the mirror successfully connects, I want to add a mirrored project but get an error.
I have tried another browser but still the same.
Hi Nat,
This will only work if both primary and mirrors are in the same domain - from the URLs you specified that doesn't seem to be the case.
Christian
Premier Support Engineer
Atlassian
From setup to deployment—this learning path shows you how to build your first app using Forge. Learn the essentials, streamline workflows, and bring custom solutions to life across Jira, Confluence, and more.
Start Learning
