Does anyone know if there is a way to let team members create snippets that belong to the workspace?
Yes, your team members will need create repository permissions within the workspace. Once they do, when they go to create a snippet, the workspace will appear in the dropdown.
We have a group created with the ability to create repositories. when group user creates a snippet & tries to save it under workspace forbidden error appears.
Can you share a screenshot of the error? Normally if they don't have access to create a snippet in the workspace, then the workspace will not appear in the dropdown.
Thank you
Don't know how, and why but error is gone & snippets are saved. Now the other question appears - if in permissions chosen "workspace" user who created snippet doesn't see it under workspace nor other users except workspace owner
When your team visits the URL for the workspace like:
https://bitbucket.org/<workspace_slug>/workspace/snippets/
What is the issue?
Have no idea what is going on, but now it works as expected. Will do a bit more testing. Thanks
That's great to hear!
This bug was fixed recently which may have resolved the issue: https://jira.atlassian.com/browse/BCLOUD-20106
Join the discussion on interview best practices and common pitfalls. Share your experiences and learn from others in the Atlassian Community.
Share you experiences!Online forums and learning are now in one easy-to-use experience.
