[Solved] Markdown links in table cells do not work
Paulius Pupeikis
February 11, 2019 edited
I am having a problem with markdown files in Bitbucket repo. My links to headers in the markdown document work only when they are not in the table. If I put them in the table the link disappears. Small working example here:
[MyLink Class](#markdown-header-mylink-class)
# MyLink class
And very similar text below that does not work:
| Name | Link |
| **MyLink** | [MyLink Class](#markdown-header-mylink-class) |
# MyLink class
Table cell with link renders simply as "MyLink Class" text.
How can I add working links to the table?
Update: asked too soon. There is some caching going on. After markdown file update rendered text does not change for some time. Links are working now.
Ana Retamal
February 13, 2019
Hi Paulius, glad you figured this out :)
Best regards,
Ana
