Sonarcloud analysis for a .NET 4.6 framework project
Pradeep Morisetti
June 12, 2023
HI,
Is there any update on sonarcloud integration with bitbucket projects using .NET framework 4.6?
I would like to create a pipeline in BB to build my .net project and produce a sonarcloud report whenever there is a commit to the repository.
Thank you.
Patrik S
June 13, 2023 edited
Hello @Pradeep Morisetti and thank you for reaching out to Atlassian Community!
Sonacloud has a bitbucket pipe available that can be used to scan your code during your build:
However, I'm afraid this pipe is not currently compatible with .NET Framework, as this needs a Windows environment to run.
Since this pipe is developed and supported by SonnarCloud, I would suggest reaching out to them to check if they have any alternative integration with Bitbucket Cloud when using .NET Framework. You can contact them using one of the options listed at https://sonarcloud.io/contact.
Thank you, @Pradeep Morisetti !
Patrik S
