Spring WebApplicationContext could not be started, after migrating stash from one server to another
Deleted user May 24, 2018 edited
After copying the stash home and stash bin directory from one server to another, and starting stash I get this:
2018-05-24 15:17:57,496 INFO [localhost-startStop-1] c.a.s.i.server.BuildInfoLogger Starting Stash 2.8.1 (aad8132 built on Wed Oct 02 01:38:50 CEST 2013)
2018-05-24 15:17:57,496 INFO [localhost-startStop-1] c.a.s.i.server.BuildInfoLogger JVM: Oracle Corporation Java HotSpot(TM) 64-Bit Server VM 1.8.0_162-b12
2018-05-24 15:18:01,011 INFO [localhost-startStop-1] c.a.s.internal.home.HomeLockAcquirer Successfully acquired lock on home directory C:\stash-home for 2156@appsrv
2018-05-24 15:18:23,730 WARN [localhost-startStop-1] o.h.s.j.d.i.StandardDialectResolver HHH000385: Unknown Microsoft SQL Server major version [12] using SQL Server 2000 dialect
2018-05-24 15:18:29,230 ERROR [localhost-startStop-1] o.h.p.p.j.JavassistLazyInitializer HHH000142: Javassist Enhancement failed: com.atlassian.crowd.model.user.InternalUser
java.lang.VerifyError: (class: com/atlassian/crowd/model/user/InternalUser_$$_javassist_17, method: _d26implies signature: (Ljavax/security/auth/Subject;)Z) Illegal use of nonvirtual function call
at java.lang.Class.getDeclaredFields0(Native Method) ~[na:1.8.0_162]
at java.lang.Class.privateGetDeclaredFields(Class.java:2583) ~[na:1.8.0_162]
at java.lang.Class.getField0(Class.java:2975) ~[na:1.8.0_162]
at java.lang.Class.getField(Class.java:1701) ~[na:1.8.0_162]
at javassist.util.proxy.ProxyFactory.setField(ProxyFactory.java:518) ~[javassist-3.15.0-GA.jar:na]
at javassist.util.proxy.ProxyFactory.createClass3(ProxyFactory.java:503) ~[javassist-3.15.0-GA.jar:na]
at javassist.util.proxy.ProxyFactory.createClass2(ProxyFactory.java:487) ~[javassist-3.15.0-GA.jar:na]
at javassist.util.proxy.ProxyFactory.createClass1(ProxyFactory.java:423) ~[javassist-3.15.0-GA.jar:na]
at javassist.util.proxy.ProxyFactory.createClass(ProxyFactory.java:395) ~[javassist-3.15.0-GA.jar:na]
at org.hibernate.proxy.pojo.javassist.JavassistLazyInitializer.getProxyFactory(JavassistLazyInitializer.java:163) ~[hibernate-core-4.2.4.Final.jar:4.2.4.Final]
at org.hibernate.proxy.pojo.javassist.JavassistProxyFactory.postInstantiate(JavassistProxyFactory.java:66) ~[hibernate-core-4.2.4.Final.jar:4.2.4.Final]
at org.hibernate.tuple.entity.PojoEntityTuplizer.buildProxyFactory(PojoEntityTuplizer.java:229) ~[hibernate-core-4.2.4.Final.jar:4.2.4.Final]
at org.hibernate.tuple.entity.AbstractEntityTuplizer.<init>(AbstractEntityTuplizer.java:212) ~[hibernate-core-4.2.4.Final.jar:4.2.4.Final]
at org.hibernate.tuple.entity.PojoEntityTuplizer.<init>(PojoEntityTuplizer.java:82) ~[hibernate-core-4.2.4.Final.jar:4.2.4.Final]
at sun.reflect.GeneratedConstructorAccessor85.newInstance(Unknown Source) [na:1.8.0_162]
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45) [na:1.8.0_162]
at java.lang.reflect.Constructor.newInstance(Constructor.java:423) [na:1.8.0_162]
at org.hibernate.tuple.entity.EntityTuplizerFactory.constructTuplizer(EntityTuplizerFactory.java:135) [hibernate-core-4.2.4.Final.jar:4.2.4.Final]
at org.hibernate.tuple.entity.EntityTuplizerFactory.constructDefaultTuplizer(EntityTuplizerFactory.java:188) [hibernate-core-4.2.4.Final.jar:4.2.4.Final]
at org.hibernate.tuple.entity.EntityMetamodel.<init>(EntityMetamodel.java:341) [hibernate-core-4.2.4.Final.jar:4.2.4.Final]
at org.hibernate.persister.entity.AbstractEntityPersister.<init>(AbstractEntityPersister.java:507) [hibernate-core-4.2.4.Final.jar:4.2.4.Final]
at org.hibernate.persister.entity.SingleTableEntityPersister.<init>(SingleTableEntityPersister.java:146) [hibernate-core-4.2.4.Final.jar:4.2.4.Final]
at sun.reflect.GeneratedConstructorAccessor84.newInstance(Unknown Source) [na:1.8.0_162]
at org.hibernate.persister.internal.PersisterFactoryImpl.create(PersisterFactoryImpl.java:163) [hibernate-core-4.2.4.Final.jar:4.2.4.Final]
at org.hibernate.persister.internal.PersisterFactoryImpl.createEntityPersister(PersisterFactoryImpl.java:135) [hibernate-core-4.2.4.Final.jar:4.2.4.Final]
at org.hibernate.internal.SessionFactoryImpl.<init>(SessionFactoryImpl.java:385) [hibernate-core-4.2.4.Final.jar:4.2.4.Final]
at org.hibernate.cfg.Configuration.buildSessionFactory(Configuration.java:1790) [hibernate-core-4.2.4.Final.jar:4.2.4.Final]
at org.hibernate.cfg.Configuration.buildSessionFactory(Configuration.java:1861) [hibernate-core-4.2.4.Final.jar:4.2.4.Final]
at org.springframework.orm.hibernate4.LocalSessionFactoryBuilder.buildSessionFactory(LocalSessionFactoryBuilder.java:247) [spring-orm-3.2.4.RELEASE.jar:3.2.4.RELEASE]
at org.springframework.orm.hibernate4.LocalSessionFactoryBean.buildSessionFactory(LocalSessionFactoryBean.java:373) [spring-orm-3.2.4.RELEASE.jar:3.2.4.RELEASE]
at com.atlassian.stash.internal.hibernate.ExtendedLocalSessionFactoryBean.buildSessionFactory(ExtendedLocalSessionFactoryBean.java:90) [stash-dao-impl-2.8.1.jar:na]
at org.springframework.orm.hibernate4.LocalSessionFactoryBean.afterPropertiesSet(LocalSessionFactoryBean.java:358) [spring-orm-3.2.4.RELEASE.jar:3.2.4.RELEASE]
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1541) [spring-beans-3.2.4.RELEASE.jar:3.2.4.RELEASE]
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1479) [spring-beans-3.2.4.RELEASE.jar:3.2.4.RELEASE]
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:521) [spring-beans-3.2.4.RELEASE.jar:3.2.4.RELEASE]
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:458) [spring-beans-3.2.4.RELEASE.jar:3.2.4.RELEASE]
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:314) [spring-beans-3.2.4.RELEASE.jar:3.2.4.RELEASE]
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:194) [spring-beans-3.2.4.RELEASE.jar:3.2.4.RELEASE]
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:323) [spring-beans-3.2.4.RELEASE.jar:3.2.4.RELEASE]
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:107) [spring-beans-3.2.4.RELEASE.jar:3.2.4.RELEASE]
at org.springframework.beans.factory.support.ConstructorResolver.resolveConstructorArguments(ConstructorResolver.java:615) [spring-beans-3.2.4.RELEASE.jar:3.2.4.RELEASE]
at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:148) [spring-beans-3.2.4.RELEASE.jar:3.2.4.RELEASE]
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:1045) [spring-beans-3.2.4.RELEASE.jar:3.2.4.RELEASE]
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:949) [spring-beans-3.2.4.RELEASE.jar:3.2.4.RELEASE]
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:487) [spring-beans-3.2.4.RELEASE.jar:3.2.4.RELEASE]
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:295) [spring-beans-3.2.4.RELEASE.jar:3.2.4.RELEASE]
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:223) [spring-beans-3.2.4.RELEASE.jar:3.2.4.RELEASE]
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:292) [spring-beans-3.2.4.RELEASE.jar:3.2.4.RELEASE]
at org.springframework.beans.factory.support.DefaultListableBeanFactory.findAutowireCandidates(DefaultListableBeanFactory.java:912) [spring-beans-3.2.4.RELEASE.jar:3.2.4.RELEASE]
at org.springframework.beans.factory.support.DefaultListableBeanFactory.doResolveDependency(DefaultListableBeanFactory.java:855) [spring-beans-3.2.4.RELEASE.jar:3.2.4.RELEASE]
at org.springframework.beans.factory.support.DefaultListableBeanFactory.resolveDependency(DefaultListableBeanFactory.java:770) [spring-beans-3.2.4.RELEASE.jar:3.2.4.RELEASE]
at org.springframework.beans.factory.support.ConstructorResolver.resolveAutowiredArgument(ConstructorResolver.java:795) [spring-beans-3.2.4.RELEASE.jar:3.2.4.RELEASE]
at org.springframework.beans.factory.support.ConstructorResolver.createArgumentArray(ConstructorResolver.java:723) [spring-beans-3.2.4.RELEASE.jar:3.2.4.RELEASE]
...(to many characters to display)
Stash v2.8.1 running with java 1.7.0_40 on Windows Server 2008 R2
atlassian-stash.log
corix AG
May 25, 2018
I found the Issue:
I used a MSSQL Server 2014, which is not supported by Stash 2.8.1
see BSERV-4296
Jobin Kuruvilla [Adaptavist]
May 25, 2018
Cool, good to know!
May 25, 2018
Can you check the Java version on the old server?
corix AG
May 25, 2018
same version, but in the server edition
 java -version
java version "1.7.0_40"
Java(TM) SE Runtime Environment (build 1.7.0_40-b43)
Java HotSpot(TM) 64-Bit Server VM (build 24.0-b56, mixed mode)
