×Hi.
I unzipped the Stash 1.3.1, set the Stash_home and ran.
When you open the browser on port 7990, it takes to load and then displays the error:
A fatal error has occurred
The Following problems occurred Which Prevents starting from Atlassian Stash Correctly:
Required com.atlassian.activeobjects.activeobjects plugin-plugin has failed to start
Required plugin com.atlassian.templaterenderer.api has failed to start
Required com.atlassian.soy.soy plugin-template-plugin has failed to start
Required plugin com.atlassian.oauth.consumer.sal has failed to start
Required com.atlassian.stash.stash plugin-scm-git has failed to start
Required plug-com.atlassian.stash.stash embcwd-admin-spi-impl has failed to start
Required plugin com.atlassian.crowd.embedded.admin has failed to start
Required plugin com.atlassian.oauth.admin has failed to start
Required plugin com.atlassian.stash.stash-velocity-helper has failed to start
Required plugin com.atlassian.oauth.consumer has failed to start
Required plugin com.atlassian.auiplugin has failed to start
Required com.atlassian.stash.stash-jira-plugin integration has failed to start
Required com.atlassian.applinks.applinks plugin-plugin has failed to start
Required com.atlassian.plugins.less-plugin-plugin transformer has failed to start
Required plugin com.atlassian.upm.atlassian-universal-plugin-manager-plugin has failed to start
Required com.atlassian.stash.stash plugin-rest-common has failed to start
Required com.atlassian.stash.stash plugin-l10n has failed to start
Required plugin com.atlassian.oauth.serviceprovider.sal has failed to start
Required plugin com.atlassian.stash.stash-salt has failed to start
Required plugin com.atlassian.stash.stash-rest has failed to start
Required com.atlassian.stash.stash plugin-scm-request-checks has failed to start
Required plugin com.atlassian.oauth.serviceprovider has failed to start
Required com.atlassian.plugins.rest.atlassian plugin-rest-module has failed to start
Required com.atlassian.templaterenderer.atlassian plugin-template-renderer-plugin-velocity1.6 has failed to start
Greats,
Eduardo
Hi Eduardo,
java.net.BindException: Address already in use <null>:7990
This means you're already running an instance of Stash (or something that's running on port 7990). You need to stop your current instance, and run './bin/stop-stash.sh' to kill the other remaining instance. You might also want to run 'ps -eaf | grep stash' to confirm Stash is no longer running.
If you see the previous errors from your original message, and I suspect you might, please raise a support ticket (https://support.atlassian.com) and attached all the files from $STASH_HOME/logs/ so we can help diagnose the problem further.
Charles
Hi Eduardo,
I'm sorry to hear you install didn't work. Unfortunately those errors don't really tell the whole story. If you wouldn't mind raising a support ticket with your logs attached we can take a closer look.
Charles
I performed again with the-fg and messages were:
http://pastebin.com/E4iGRZLm (The message is long and the characters exceed the limit)
If you can help me I am very grateful because we intend to acquire Jira, GreenHopper, bonfire, and Confluence Stash together.
Eduardo
