Hello Community Members,
currently, we are using bitbucket cloud and Bitbucket Pipelines.
I have a pipeline that has several steps which are executed automatically, but we also have some steps in that pipeline which should be triggered manually before it continues to the next step.
An example is doing smoke tests on INT environment before deploying the app to the UAT environment.
So , is there a way that email notification is sent to the developer who triggered the pipeline that the build step has been reached and needs a manual intervention to continue the pipeline.
Currently, we dont get any emails when our pipelines reach the manual trigger step.
Example:
pipeline
- step1
Build
- step2
unit test
- step3
deploy to INT
- step4
desc: Do smoke tests
trigger: manual
- step5
deploy to UAT
Hi Bharath,
Did you get the solution for this? I also have similar requirement. Could you please provide me some guidance how you achieved this?
Regds
Jamie
AI is reshaping the dev experience, with faster builds but adding more friction. See what 3,500 developers and managers say about productivity, tools, and team alignment in Atlassian’s State of Developer Experience report 2025.
Explore the report
