Trigger pipeline based on commits in another repo
Aurimas N_
I want to use the following pattern, but can't figure a way to do it in bitbucket pipelines.
Repo A (bussiness app A)
Repo B (k8s manifests for business app A, also pipeline definition)
Workflow:
Once there is merge to main branch in Repo A, pipeline from repo B triggers.
This is for concern separation, people developing app A are not necessary the same who are responsible for build pipelines and infra, so there is no need to clutter their repo with pipeline definition and infra elements. I've been sucessfully using this pattern in another ecosystem, how close can I get with bitbucket pipelines?
Theodora Boudale
April 26, 2024
Hi Aurimas,
One option is to use a pipeline in repo A that will run on the main branch only, and the only thing it will do is trigger a build in repo B. You can use the following pipe in the yml file of repo A, to trigger a build in repo B:
You could also use our API instead:
Another option would be to use a webhook in repo A that gets triggered on repo push events. A webhook can send a request to a server of yours every time the event you have selected in the triggers occurs. After the request is received by your server, you can check the webhook payload to see if the push was made to the main branch and then use our API to trigger the pipeline in repo B.
Please feel free to reach out if you have any questions!
Theodora
atlassian, forge, forge learning path, atlassian learning, cloud app development, forge app development, build forge apps, atlassian certification, developer training, jira app development, confluence app development, automation, ui frameworks
Turn Ideas into Atlassian Apps 📱
From setup to deployment—this learning path shows you how to build your first app using Forge. Learn the essentials, streamline workflows, and bring custom solutions to life across Jira, Confluence, and more.
Start Learning
