×when i click on clone button through sourcetree but I am unable to clone a code on my local machine.
Can you tell me steps how to clone the repository from bitbucket to my local machine?
Also help me what should i do when i get 407 proxy error?
The following document explains the clone process in more detail:
https://confluence.atlassian.com/display/BITBUCKET/Clone+Your+Git+Repo+and+Add+Source+Files
Fixing 407 Error Code
A 407 error detected via a Web browser can often be resolved by navigating to the URL in a slightly different way e.g. accessing another URL for the proxy server first. Your ISP should be able to explain the role of the proxy server in their security setup and how you should use it. If you are monitor your website through 100pulse, we will intimate whenever you encounter 407 status code error through e-mail or Short message service.
Hope this helps!
