Unauthorized fatal: Could not read from remote repository.
Muhammad Hassan
February 20, 2024
Hi everyone!
I am working on a bitbucket pipeline. I have a workspace with multiple repositories. Previously, I was able to fetch and clone all the repos from the workspace. But now, I don't know whats happening, it is clonning some repositories from the workspace while giving this error on other repositories in workspace
Warning: Permanently added the ECDSA host key for IP address 'XXX.XX:XX:XXX' to the list of known hosts.
Unauthorized
Please make sure you have the correct access rights
and the repository exists.
A little background of my work,
I am creating a custom user in container and shifting the private ssh-key from /opt/atlassian/pipelines/agent/ssh/ /home/customuser/.ssh/ folder. I previosuly fixed all issues and it was working fine too. But after playing a little bit with pipeline, I am not able to fix it up again. Even when I run pipeline on the commit which was working, it is givinge me above error for some repos while easily clonning some repos from the same workspace.
Any indication of this error from the community will be highly regarded.
Syahrul
February 21, 2024
Hey @Muhammad Hassan
Welcome to the community!
Can you check our blog on cloning from another repository via pipeline and see if that helps you figure out the issue?
Cloning another Bitbucket repository in Bitbucket Pipelines
Syahrul
atlassian, bitbucket, ci/cd workflows, scale ci cd, bitbucket webinar, devops pipeline, continuous integration, continuous delivery, atlassian learning, software automation, developer tools, build and deploy, pipeline optimization, atlassian community
Scale CI/CD workflows faster with Bitbucket Pipelines 🪣
Join this webinar on June 25/26th to learn how to build secure CI/CD workflows using Bitbucket Pipelines and get tips from our own engineers on how to speed up builds and operate at scale.
Register today
