Unit tests failed
fatma_elbehi August 6, 2021
while trying to run unit tests in bitbucket, the pipeline failed.
Language: Java
This is the error that I got
Mark C
August 25, 2021
Hi @fatma_elbehi ,
Thank you for reach out to the community.
To be honest, I'm not really sure the reason why the build is failing and giving the error message.
However, would it be possible for you to try to test your Pipelines build locally in a Docker container to see if you're also experiencing the same issue?
This is for us to compare the result outside Bitbucket Pipelines.
Thanks and let me know how it goes.
Mark C
fatma_elbehi September 10, 2021
Hi Mark,
Thank you for your reply!
I'll try this trick and then get back to you.
Best,
Fatma
Mark C
September 13, 2021
Sure. Let me know how it goes.
Mark C
