Today I have big problems trying to add various repositories to various projects in one of our public Bitbucket Cloud workspaces.
In some cases it works fine, but for others I only get a number of errors not specifying what is wrong.
I have tried both ways to do this as specified here: Add repositories to a project | Bitbucket Cloud | Atlassian Support
Just to mention, I have never had this problem before, but now I am not able to sort out what the problem might be.
So, I sincerely hope somebody "out there" can help me out.
Best Regards Anne Orton
Hello @Anne Orton and welcome to Atlassian Community!
I tried reproducing the same error on my personal instance with no success, and unfortunately, the error message being returned does not bring much information with regard to the cause of the issue. In this case, I would suggest we try to rule out any possible local browser issue with the following tests :
If after doing those tests you are still facing the issue, we might need additional logs from your browser to understand why that particular operation is failing. In that case, you can let me know here and I can go ahead and raise an internal ticket to investigate this further.
Thank you, @Anne Orton !
Patrik S
Hi Patrik,
Many thanks for trying to help me out.
1. I have tried Chrome and Edge - latest stable version and Firefox 110. Same result in all of them.
2. Using an Incognito window in Chrome - same result:
3. I have disabled all extensions in Chrome except for Microsoft defender:
This still results in the 4 impossible to interpret error messages:
So, consequently I am stuck and have no clue to what I am doing wrong or what the application is doing wrong.
I have done this many times in the past and have had no problems with it.
So I sincerely hope you can help me out.
Best Regards
Anne O
Hi! I'm a colleague of Anne and i have now also tried to move the repository. I also get the same error message. So it seems to persist regardless of who tries to move it.
Hi @Patrik S
I just wonder if you have had any opportunity to have a further look into our problem with adding repositories to projects as described above?
Best Regards
Anne
Hello @Anne Orton and @Stella Wrååk ,
Thank you very much for sharing the results of the testing.
I will raise an internal ticket for you in order to investigate this further, as we will need you to share some additional logs from your browser session. You should be receiving the ticket link soon, but in case you don't receive it, please let me know so I can share the link with you here (only you and Atlassian staff will be able to view the ticket).
Patrik S
Get Certified! ✍️Online forums and learning are now in one easy-to-use experience.
