We have a lot of projects.
Some projects have already ended and exist only on bitbucket.
The project has been closed and is rarely accessed by users.
But I don't want to clear it for the record.
The problem is that when you run bitbucket, both currently used and unused projects are displayed.
What would be the best way to operate?
You could change the project name in Project settings from 'MyProject' to 'MyProject_OBSOLETE'
The project key can remain the same.
Hope it helps.
Best, Ulrich
// Izymes - Tools for efficient teams
