Updating $PATH while running a bitbucket pipeline
Misha (HS) March 11, 2022
I'm working with hashicorp/terraform:latest image (which is very minimal) and need to install go. After installing go into /usr/local. As a next step we need to update $PATH so that we could run go commands. But the export PATH does not take and the shell can't find go executable which is in /usr/local/go/bin.
We can't quite figure out how to go about this. Help is greatly appreciated!
image: hashicorp/terraform:latest
pipelines:
branches:
dev:
- step:
name: Build & deploy [dev]
# image: golang
deployment: Dev
script:
- apk add bash
- apk add zip
- source bitbucket-pipelines.sh
- cd ${IMPORT_PATH}
# Install go
- tar -C /usr/local -xzf go1.17.2.linux-amd64.tar.gz
- ls -la /usr/local/go/bin
- export PATH=$PATH:/usr/local/go/bin
- echo $PATH
- echo $0 # show shell exec
- go version # this fails with file not found
Theodora Boudale
March 14, 2022
Hi @Misha (HS),
I have tried to reproduce this locally by running a Docker container with the image you are using:
docker run -it --entrypoint=/bin/sh hashicorp/terraform:latest
and then I executed the commands you have in your yml file (apart from lines 3 and 4 of the script)
The command go version also fails when debugging this locally.
If I try the installation in a different Docker container, e.g. atlassian/default-image:3 which is based on Ubuntu, the installation of go seems to succeed (both locally and in Pipelines).
It is possible that the file you are downloading is not the correct one for Alpine Linux or extra/different steps may be needed for the installation in Alpine. I'm afraid I don't know what exactly is causing the problem here, but it seems to be specific to the Linux distribution of the Docker image.
Theodora
Misha (HS) March 14, 2022
Oh, great, thank you Theodora. I will play with the image. It looks like Alpine does not like the compiled for amd64 go binary. I will update this ticket with what I find.
Like Theodora Boudale likes this
Jack Nolddor _Sweet Bananas_
March 14, 2022 edited
Pre-compiled go binary seems not to be compatible with alpine.
You can see an example of how to build go from source on alpine at this dockerfile
https://github.com/docker-library/golang/blob/67757c0feeb9867a54801ca378dcfc55b9db7e70/1.17/alpine3.15/Dockerfile
Better option would be as suggested already by Atlassian team to use another image based on Debian / Ubuntu
Regards
Theodora Boudale
March 15, 2022
Thanks for posting that example Jack!
@Misha (HS), I also found the following blog post, the solution suggested there is to install go with apk:
Theodora
Hi there maybe you must add execution permissions to go binary?
chmod a+x /usr/local/go/bin/go
What I'm getting is file not found (not a permission issue)
/opt/atlassian/pipelines/agent/tmp/shellScript5553201990805023401.sh: line 37: go: not found
atlassian, compass, developer experience, devex, platform engineering, internal developer platform, component catalog, atlassian learning, productivity tools, developer productivity, software architecture, compass webinar, engineering teams
Discover how Compass drives DevEx and productivity at Atlassian 🏃🏻‍♂️
Learn why Compass was built to tackle dev experience at scale. See how Atlassian uses it to boost visibility, reduce cognitive load, and drive consistency—plus tips to get started and customize your IDP for stronger team engagement.
Join the webinar ✨
