Use of Docker Compose and Python 3.11 in bitbucket pipeline
Pasquale Lafiosca January 10, 2025
To test my repo, I need to run:
docker compose build
docker compose up -d
inside the pipeline. I also need Python 3.11.
First, I am not sure what image to use.
After several attempts I went back to the recommended `atlassian/default-image:4
` and manually installing python at the beginning. I don't like it but it works.
Second, I tried to use the docker service but apparently there is no docker compose in it.
Failed miserably.
Third, I manually installed all the dependencies using the commands as per official Docker documentation https://docs.docker.com/engine/install/ubuntu/
However, I get the error command not found: tee, even after installing the necessary package with apt install -y --reinstall coreutils
What is the easiest way to test my code that depends on docker compose V2 AND Python 3.11???
Thanks.
Theodora Boudale
January 13, 2025
Hi Pasquale and welcome to the community!
Docker compose is available in the image atlassian/default-image:4 as docker-compose. Please keep in mind that Docker compose v2 (which is preinstalled in atlassian/default-image:4) won't work with buildkit. Docker compose with buildkit builder by default requires privileged mode, which is disabled in Bitbucket Pipelines for security reasons. If you want to use Docker compose v2, you will need to disable buildkit by adding the command export DOCKER_BUILDKIT=0 in your yml file, in the Pipelines step that uses docker-compose. Restricted Docker commands and options are listed in this page:
Installing Docker Engine during your build won't work. Every pipelines step runs in a Docker container, and unless you use the docker service that Pipelines provide your build won't have access to a Docker daemon.
You can build your own Docker image that includes both python:3.11 and docker-compose, and use that as a build container in your Pipelines builds. You can install Docker Compose standalone (in images that don't include it) by following the instructions on this page:
You can use as base image python:3.11, or you could use a different one, e.g. alpine, ubuntu, debian and then install Python 3.11, docker-compose and any other tools you need by adding the necessary commands in the Dockerfile. You can then build and push this image to a Docker registry and reference it in your yml file. We support public and private Docker images including those hosted on Docker Hub, AWS, GCP, Azure and self-hosted registries accessible on the internet:
Finally, if you want to run docker commands that are restricted in Pipelines, you can use a self-hosted runner instead for a specific Pipelines step:
If you use a Linux Docker runner, you will need to define a custom dind image for the Docker service, so that you won't run into the same restrictions as cloud-based builds:
Please feel free to let me know if you have any questions.
Theodora
Pasquale Lafiosca January 14, 2025
Thanks. I'll look into this.
Like • Theodora Boudale likes this
Theodora Boudale
January 14, 2025
You are very welcome. Please feel free to reach out if you have any questions!
Pasquale Lafiosca February 15, 2025
As an update, the custom docker image I created and hosted on the hub works.
I have more control over the process. However, Bitbucket does not cache it and rather re-builds the image every time for no apparent reason.
Not really effective to do a 3 minute building for 10 seconds of tests.
Theodora Boudale
February 17, 2025
Hi Pasquale,
I'm not really sure which image you are referring to now and I'm a bit confused by mentions of "building" and "re-builds".
In our earlier discussion we were talking about the Docker image that is used as a build container for a certain Pipelines step and the option of building and using a custom Docker image. If you want such a custom Docker image as a build container, there is no need to build it every time in Pipelines, unless you want different dependencies very often. You can build it once locally, push it to a Docker registry and then reference it in your bitbucket-pipelines.yml.
For images used as a build container or service containers, we cache automatically all public Docker Hub images used in Pipelines.
Are you talking about the build container's image, or about a different image you build with docker compose build during the step?
Theodora
Pasquale Lafiosca February 24, 2025
Thank you for replying.
My bad. What I mean is not "build" but rather "clone".
Bitbucket clones the docker image every time at the beginning of the pipeline.
Second issue is that despite having defined a cache with no automatic invalidation:
definitions:
    caches:
        pythonvenv: ~/venv
This does not cache anything. So dependencies are reinstalled every time.
Any help to reduce our running time is appreciated.
Thank you.
Theodora Boudale
February 25, 2025
Hi Pasquale,
Since you're talking about the beginning of the pipeline, I assume you are referring to the Docker image that is used as a build container for a Pipelines step. Are you hosting the image you use as a build container on Docker Hub or a different registry? And is it a public or a private image? If it is a public image from Docker Hub, we cache these so the image will be pulled from our cache. If it is a private image or hosted on a different registry, we do not support caching for these images when they are used as build containers.
Regarding the second issue, there are a few things to check:
  1. If you open the Pipelines page of the repo on Bitbucket's website, you will see a button named Caches near the top right corner (between the buttons Schedules and Usage). If you select that, do you see the pythonvenv cache listed?
  2. Open the page of a recent Pipelines build that should generate this cache. Select the step that should generate the cache, and then in this step's build log expand the Build teardown section. What messages do you see there about the pythonvenv cache? Only caches under 1GB once compressed are saved. If your cache is larger than 1 GB  or if there's any other issue, there should be a message about it in the Build teardown section.
  3. You can add the command ls -lahR ~/venv in the beginning and in the end of the script in the step that generates this cache. This is to double check if the cache directory has content or if it's empty.
Theodora
Pasquale Lafiosca March 19, 2025
Hi. Thank you and sorry for the late reply.
My image is public, but Bitbucket does not cache it.
To answer the second part:
1. The dependency caches are empty. Nothing listed.
2. Indeed I've found the message:
Cache "pythonvenv: ~/venv": Skipping upload for empty cache
I've found that the directory path was wrong. This solves issue 2. Thank you for pointing me in the right direction!
Still looking for a solution for problem 1, i.e. caching the docker image. Its size is about 500 MB.
It is public on docker hub. Refer to decadenza/exicentrum-testenv
This is what I get in the build teardown
The docker cache will consist of all unique layers from the following images:
Usage: grep [OPTION]... PATTERNS [FILE]...
Try 'grep --help' for more information.
"docker image save" requires at least 1 argument.
See 'docker image save --help'.
Usage: docker image save [OPTIONS] IMAGE [IMAGE...]
Save one or more images to a tar archive (streamed to STDOUT by default)
chmod: cannot access '/opt/atlassian/pipelines/agent/cache/docker/docker.tar': No such file or directory
Docker images saved to cache
Cache "docker: docker.tar": Skipping upload for empty cache
Searching for test report files in directories named [test-results, failsafe-reports, test-reports, TestResults, surefire-reports] down to a depth of 4
Finished scanning for test reports. Found 0 test report files.
Merged test suites, total number tests is 0, with 0 failures and 0 errors.
Theodora Boudale
March 19, 2025
Hi Pasquale,
It's good to hear that issue 2 is resolved!
About issue 1, you posted info from the Build teardown. The docker cache mentioned in the Build teardown is for caching images that you use during a Pipelines build. It has nothing to do with the caching of an image that is used as a build container in a Pipelines steps.
So, now I have to go back to my previous question, and ask again, where exactly do you use the DockerHub image decadenza/exicentrum-testenv that you expect to be cached? Which of the following two is the case?
(1) Do you use it as a build container for a Pipelines step, similarly to one of the two following definitions?
image: decadenza/exicentrum-testenv
pipelines:
default:
- step:
script:
- echo "Hello, World!"
pipelines:
default:
- step:
script:
(2) Or do you use this image during your Pipelines build in a docker command, e.g. something like the following (or with a different docker command)?
pipelines:
default:
- step:
script:
- docker pull decadenza/exicentrum-testenv
Theodora
Sahir Maharaj
January 11, 2025
Hello @Pasquale Lafiosca
From my experience, using Docker Compose and Python 3.11 in Bitbucket Pipelines requires careful image selection and setup. The recommended atlassian/default-image:4 works, but it’s inefficient to manually install Python.
Consider creating a custom Docker image that includes both Python 3.11 and Docker Compose pre-installed to streamline your pipeline.
For the error with tee, ensure that all required dependencies are installed in your pipeline’s environment. If the issue persists, consult Docker documentation or contact Atlassian support at https://support.atlassian.com/contact/#/ for guidance on optimizing your setup.
Thanks. I think custom docker images are the way to go.
Product Admin Site Admin
