Using YAML anchors in multiple steps
warmannj
November 9, 2019 edited
HI,
My pipeline has multiple steps and I'm trying to get it to work for multiple environments. It was working fine for one environment.  I already followed the guide in this document: https://confluence.atlassian.com/bitbucket/yaml-anchors-960154027.html?_ga=2.260751877.964504472.1573266564-336097571.1573266564
But it doesn't appear to be correct as I get the error: `There is an error in your bitbucket-pipelines.yml at [pipelines > branches > develop > 0]. To be precise: Step is empty, null, or missing.`, when following the syntax in the example directly.
Here's my pipeline yml file:
image: atlassian/default-image:2
definitions:
  steps:
  - step: &pushToECR
  name: Push to ECR
  script:
    - unset NPM_CONFIG_USER
    - docker build -t $ECR_IMAGE_NAME .
    - pipe: atlassian/aws-ecr-push-image:1.0.1
    variables:
      AWS_ACCESS_KEY_ID: '$AWS_ACCESS_KEY_ID'
      AWS_SECRET_ACCESS_KEY: '$AWS_SECRET_ACCESS_KEY'
      AWS_DEFAULT_REGION: '$AWS_REGION'
      IMAGE_NAME: '$ECR_IMAGE_NAME'
- step: &deployToECS
name: Deploy to ECS
deployment: development
services:
- docker
script: # Modify the commands below to build your repository.
- pipe: atlassian/aws-ecs-deploy:1.0.4
  variables:
    AWS_ACCESS_KEY_ID: $AWS_ACCESS_KEY_ID
    AWS_SECRET_ACCESS_KEY: $AWS_SECRET_ACCESS_KEY
    AWS_DEFAULT_REGION: $AWS_REGION
    CLUSTER_NAME: '$ECS_CLUSTER_NAME'
    SERVICE_NAME: '$ECS_SERVICE_NAME'
    TASK_DEFINITION: '$ECS_TASK_DEFINITION_FILE'
    DEBUG: 'true'
pipelines:
  branches:
    develop:
      - step:
        <<: *pushToECR
   - step:
     <<: *deployToECS
Rupert Broad
A little difficult to tell if the problem is with your yaml formatting - it's all out of whack - or the code itself. I would guess the issue is that you haven't declared "deployment" in your pushtoEcr definition.
atlassian, forge, forge learning path, atlassian learning, cloud app development, forge app development, build forge apps, atlassian certification, developer training, jira app development, confluence app development, automation, ui frameworks
Turn Ideas into Atlassian Apps 📱
From setup to deployment—this learning path shows you how to build your first app using Forge. Learn the essentials, streamline workflows, and bring custom solutions to life across Jira, Confluence, and more.
Start Learning
