Using environment variables within strings (interpolation) to output JSON
Skowronek
March 7, 2019 edited
Given a pipeline env variable $MYVAR, how would one write the pipeline script command to interpolate the env var within my pipeline YAML? Here is very basic example:
script:
  - echo '{"myvar":"$MYVAR"}' > ~/file.json
Right now, the $MYVAR is not getting interpolated. have tried ${MYVAR} as well. Haven't found a lot of examples unfortunately.
Thanks.
Graham Gatus
April 16, 2019 edited
@Skowronek in your example, the MYVAR variable wasn't interpolated due to the single quotes - you need to swap this out for double quotes. Alternatively, you can also use a 'here' document. Below is an example showing the broken approach, and two working approaches; double quoting, and using a here document:
image: atlassian/default-image:2
pipelines:
default:
- step:
script:
# Broken due to single quotes, bash wont substitute $MYVAR.
- echo '{"myvar":"$MYVAR"}' > file1.json
- cat file1.json
# Works - escaping with double quotes.
- echo "{\"myvar\":\"$MYVAR\"}" > file2.json
- cat file2.json
# Works - using a here document, see http://tldp.org/LDP/abs/html/here-docs.html
cat <<EOF > file3.json
{"myvar":"${MYVAR}"}
EOF
- cat file3.json
Graham Gatus
I'd also recommend using the 'jq' tool (https://stedolan.github.io/jq/) when trying to generate json. You can use it with variable substitution to build up complex json strings, e.g
jq -n --arg varname "$MYVAR" '{"myvar": $varname }'
