ValueError: Please specify a container name when using atlassian/azure-storage-deploy:2.2.1 pipe
Maruf
May 7, 2024
yml
 - step:
          name: Deploy to Azure
          deployment: Production
          script:
            - pipe: atlassian/azure-storage-deploy:2.2.1
              variables:
                SOURCE: 'build'
                DESTINATION_STORAGE_ACCOUNT_NAME: 'https://xxxxxxxx.blob.core.windows.net'
                DESTINATION_SAS_TOKEN: $SAS_TOKEN3
                DESTINATION_CONTAINER_NAME: '$web'
                DEBUG: 'true'
We have tried using escape character (‘///$web’ and â€˜//$web’) to take the name $web but we get the same error
Igor Stoyanov
May 10, 2024
@Maruf hi. Have you tried this solution:
'\$web'
according to Escape character Bash
Regards, Igor
Mark C
May 9, 2024
Hi @Maruf,
Welcome to the community.
Before the Pipe script, would you be able to print the $web environment variable to ensure it is not empty?
- echo $web
Also, could you try to use a static string name and see if the Pipe is running after that?
Mark C
Igor Stoyanov
May 10, 2024
@Mark C . It is not an environment variable, it is the default name of Azure Storage Container.
Regards, Igor
