[2025-03-12 20:14:00,729] Updating runner status to "ONLINE" and checking for new steps assigned to the runner after 0 seconds and then every 30 seconds.
[2025-03-12 20:14:00,730] Updating runner state to "ONLINE".
[2025-03-12 20:14:00,845] An error occurred whilst updating runner state to "ONLINE".
org.springframework.web.reactive.function.client.WebClientResponseException$BadRequest: 400 Bad Request from POST https://auth.atlassian.com/oauth/token
at org.springframework.web.reactive.function.client.WebClientResponseException.create(WebClientResponseException.java:217)
Suppressed: reactor.core.publisher.FluxOnAssembly$OnAssemblyException:
Error has been observed at the following site(s):
*__checkpoint ⇢ 400 from POST https://auth.atlassian.com/oauth/token [DefaultWebClient]
Original Stack Trace:
at org.springframework.web.reactive.function.client.DefaultClientResponse.lambda$createException$1(DefaultClientResponse.java:207)
at reactor.core.publisher.FluxMap$MapSubscriber.onNext(FluxMap.java:106)
at reactor.core.publisher.FluxOnErrorReturn$ReturnSubscriber.onNext(FluxOnErrorReturn.java:162)
at reactor.core.publisher.FluxDefaultIfEmpty$DefaultIfEmptySubscriber.onNext(FluxDefaultIfEmpty.java:101)
at reactor.core.publisher.FluxMapFuseable$MapFuseableSubscriber.onNext(FluxMapFuseable.java:129)
at reactor.core.publisher.FluxContextWrite$ContextWriteSubscriber.onNext(FluxContextWrite.java:107)
at reactor.core.publisher.FluxMapFuseable$MapFuseableConditionalSubscriber.onNext(FluxMapFuseable.java:299)
at reactor.core.publisher.FluxFilterFuseable$FilterFuseableConditionalSubscriber.onNext(FluxFilterFuseable.java:337)
at reactor.core.publisher.Operators$MonoSubscriber.complete(Operators.java:1839)
at reactor.core.publisher.MonoCollect$CollectSubscriber.onComplete(MonoCollect.java:160)
at reactor.core.publisher.FluxMap$MapSubscriber.onComplete(FluxMap.java:144)
at org.springframework.cloud.sleuth.instrument.reactor.ScopePassingSpanSubscriber.onComplete(ScopePassingSpanSubscriber.java:103)
at reactor.core.publisher.FluxPeek$PeekSubscriber.onComplete(FluxPeek.java:260)
at reactor.netty.channel.FluxReceive.onInboundComplete(FluxReceive.java:415)
at reactor.netty.channel.ChannelOperations.onInboundComplete(ChannelOperations.java:439)
at reactor.netty.channel.ChannelOperations.terminate(ChannelOperations.java:493)
at reactor.netty.http.client.HttpClientOperations.onInboundNext(HttpClientOperations.java:796)
at reactor.netty.channel.ChannelOperationsHandler.channelRead(ChannelOperationsHandler.java:115)
at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:444)
at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:420)
at io.netty.channel.AbstractChannelHandlerContext.fireChannelRead(AbstractChannelHandlerContext.java:412)
at io.netty.channel.CombinedChannelDuplexHandler$DelegatingChannelHandlerContext.fireChannelRead(CombinedChannelDuplexHandler.java:436)
at io.netty.handler.codec.ByteToMessageDecoder.fireChannelRead(ByteToMessageDecoder.java:346)
at io.netty.handler.codec.ByteToMessageDecoder.channelRead(ByteToMessageDecoder.java:318)
at io.netty.channel.CombinedChannelDuplexHandler.channelRead(CombinedChannelDuplexHandler.java:251)
at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:442)
at io.netty.handler.ssl.SslHandler.unwrap(SslHandler.java:1503)
at io.netty.handler.ssl.SslHandler.decodeNonJdkCompatible(SslHandler.java:1377)
at io.netty.handler.ssl.SslHandler.decode(SslHandler.java:1417)
at io.netty.handler.codec.ByteToMessageDecoder.decodeRemovalReentryProtection(ByteToMessageDecoder.java:530)
at io.netty.handler.codec.ByteToMessageDecoder.callDecode(ByteToMessageDecoder.java:469)
at io.netty.handler.codec.ByteToMessageDecoder.channelRead(ByteToMessageDecoder.java:290)
at io.netty.channel.DefaultChannelPipeline$HeadContext.channelRead(DefaultChannelPipeline.java:1357)
at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:440)
at io.netty.channel.DefaultChannelPipeline.fireChannelRead(DefaultChannelPipeline.java:868)
at io.netty.channel.epoll.AbstractEpollStreamChannel$EpollStreamUnsafe.epollInReady(AbstractEpollStreamChannel.java:799)
at io.netty.channel.epoll.EpollEventLoop.processReady(EpollEventLoop.java:501)
at io.netty.channel.epoll.EpollEventLoop.run(EpollEventLoop.java:399)
at io.netty.util.concurrent.SingleThreadEventExecutor$4.run(SingleThreadEventExecutor.java:997)
at io.netty.util.internal.ThreadExecutorMap$2.run(ThreadExecutorMap.java:74)
at io.netty.util.concurrent.FastThreadLocalRunnable.run(FastThreadLocalRunnable.java:30)
at java.base/java.lang.Thread.run(Unknown Source)
G'day, @Sushanth Chinnakka
Welcome to the community!
We need more information and the complete logs of your runner to investigate the issue. I see that you are on a paid workspace plan. Please raise a support ticket at our support portal and include the full runner logs along with information about your runner type. This will help us in our investigation.
Syahrul
