What permissions are required for the aws-s3-deploy pipe?
Aaron Durant
I am creating an IAM role for my deployment pipeline, which includes using the aws-s3-deploy pipe.
Is there anywhere I can find a full list of permissions it requires to run?
Thank you
Igor Stoyanov
February 10, 2023
@Aaron Durant  hi.This pipe requires the standard permissions: check them is this guide.
Regards, Igor
Martin Davidson February 14, 2024
There is no reference to "standard permissions" in the linked guide -- it discusses several different use cases and examples of permissions.
Would you mind posting the IAM policy with the required actions and resources spelled out?
It'd be great if the IAM permissions required by each pipe could be documented in each pipe's respective README, otherwise the user of the pipe has to guess via trial-and-error or define likely overly permissive policies.
Like • 2 people like this
