What's the difference between repo and project in Bitbucket
kaizoku-kuma
October 28, 2022
just  a very simple question :
What is the betweend repo and projet in Bitbucket ?
In Github, if I'm not wrong a Repo can contain multiple projects but the other way is not possible
So in Bitbucket, is it the same or is it inverted ?
Thank you in advance,
Gauthier
6 votes
Mikael Sandberg
Projects in Bitbucket is a way to organize your repositories and apply the same configuration to those repositories, like access, branching strategy, default reviewers etc, instead of having to do that for each repository.
Mikael Sandberg
And I forgot to add, welcome to Atlassian Community @kaizoku-kuma !
Like • Leonid Tepliakov likes this
kaizoku-kuma
October 30, 2022
Hi thank you for the answer ! I understand now how it is thank you again !
Like • Mikael Sandberg likes this
Chris S
April 20, 2023
I think there is a small error in the original answer from @Mikael Sandberg. I think the list of configuratino should say instead:
"Projects in Bitbucket is a way to organize your repositories and apply the same configuration to those repositories, like access keys, branching strategy, default reviewers etc, instead of having to do that for each repository."
An Access Key is very different than Access, or Permission to access a repo. We recently had confusion in a meeting that this slight difference caused. I may be wrong though, so feel free to let me know if I missed something.
Like • 2 people like this
Zoey Wang June 25, 2023
Thanks Chris
atlassian, forge, forge learning path, atlassian learning, cloud app development, forge app development, build forge apps, atlassian certification, developer training, jira app development, confluence app development, automation, ui frameworks
Turn Ideas into Atlassian Apps 📱
From setup to deployment—this learning path shows you how to build your first app using Forge. Learn the essentials, streamline workflows, and bring custom solutions to life across Jira, Confluence, and more.
Start Learning
