What settings to use bitbucket runner autoscaler for arm64?
Ethan Stein November 6, 2024
I've been struggling to figure out what deployment.yaml settings I need to use so I can leverage arm64 for the bitbucket runner autoscaler. Hoping someone can help?
The kustomize files here appear to only be for amd64
https://bitbucket.org/bitbucketpipelines/runners-autoscaler/src/master/kustomize/
Ethan Stein November 11, 2024
Yeah, so due to the way the runner autoscaler works with automatically adding the 'linux', 'self.hosted', and 'autoscale.created' labels made it impossible to have more than one. So I had to patch my own. That also allowed me to create an ARM64 version. Now it's working. Sad they had to code it like that. Makes no sense really.
Alin Turbut December 18, 2024
@Ethan Stein care to share your version of the autoscaler that you made for ARM64 architectures?
andrii
January 13, 2025
You can make it work for ARM64 via Kustomize.
patches:
- target:
kind: Deployment
patch: |-
- op: replace
path: /spec/template/spec/containers/0/command
value:
- /bin/bash
- op: replace
path: /spec/template/spec/containers/0/args
value:
- -c
- sed -i "/DEFAULT_LABELS/s/'linux'/'linux.arm64'/g" autoscaler/core/constants.py && python autoscaler/start.py
- target:
kind: Deployment
patch: |-
- op: replace
value:
- /bin/bash
- op: replace
value:
- -c
- sed -i "/DEFAULT_LABELS/s/'linux'/'linux.arm64'/g" autoscaler/core/constants.py && python autoscaler/start_cleaner.py
Product Admin Site Admin
