Why Bitbucket allows to merge with checks not passed?
Oliver CENTENO November 24, 2022
I have setup checks in my Bitbucket to ensure:
- 1 approval
- No failed builds
- No task unresolved
- No changes requested
But the merge button is enabled and (even though there is a warning) I can do the merge.
This should not happen, otherwise what are the checks for?
Erez Maadani
November 24, 2022
Hey @Oliver CENTENO
The enforcement of merge checks is considered a premium feature and it has to be enabled.
Go to: Repo Settings -> Under Workflow to Brach Restrictions -> Add or edit a branch restriction -> Choose the merge settings tab -> Look under Merge Conditions
