×Hello,
I am experiencing an interesting issue. When I'm adding a known hosts under Pipelines > SSH Keys, the fingerprint is not the same and only rarely I get the correct fingerprint. From my testing, it looks like a hit-and-miss approach, since I'm not changing anything on my end and server is no behind firewall, but from 30 "Fetch" known hosts fingerprint, I may get 1 that is correct. I'm also getting up to three different fingerprints for the same host and don't know why.
The problem is that when I'm using Pipelines for deployment, I get a big red error in those that "WARNING: REMOTE HOST IDENTIFICATION HAS CHANGED!". But it didn't, the fingerprint obtained was wrong in the first place. After I fetch the correct key, everything works correctly.
Any ideas?
Hi Kristjan and welcome to the community!
Does this server perhaps have multiple host keys?
If you run the command
ssh-keyscan <domain_name_or_ip_address_of_server>
from your own computer, do you get multiple keys listed?
If you do get multiple ones, do their fingerprints match with the different fingerprints you get from Repository settings > SSH Keys in the Known hosts section, when you try to fetch the fingerprint?
Theodora
Hi Theodora,
I wasn't even aware that a host can have multiple keys (I'm not a linux expert, so please bear with me), I always thought that there's only one. Have ran the suggested command and I see three keys listed:
- ssh-rsa
- ecdsa-sha2-nistp256
- ssh-ed25519
I managed to get fingerprints from the response and after comparing them to the ones I get in Bitbucket, I see that all three are correct, but when deploying through pipelines, only first one works (ssh-rsa). Other two are rejected with the error message that I pasted in my first message.
I assume if I want to fix this one, I need to remove other two keys from my system? Please note that this is something new, since I do have few more servers and never noticed an issue before, only one is acting up that I created recently.
Best regards,
Kristjan
Hey @Kristjan Ortego
In SSH, it's common for a host to have multiple public keys associated with different encryption algorithms. Each key type offers various levels of security and performance, and SSH clients and servers can negotiate which type to use during the connection setup.
You don't have to remove the host keys; instead, it's because the server you're connecting to might be configured to prefer "ssh-rsa"
. If it prefers ssh-rsa
, then that's likely why it's working when the other two are not. This could be configured in the server's SSH configuration file (typically /etc/ssh/sshd_config
), where you can specify which key types are accepted.
I hope this helps.
Syahrul
