android building failed on bitbucket pipeline during lintVital
Aaron_김윤호 December 12, 2021
Recently, I configured Bitbucket Pipeline to build the android apk.
Here is the `bitbucket-pipelines.yml`
pipelines:
    custom:
    QA:
      - step:
        caches:
          - gradle
        script:
          - echo "$KEYSTORE_FILE_BASE64" | base64 -d > android-signing-keystore.jks
          - export GRADLE_OPTS='-XX:+UseG1GC -XX:MaxGCPauseMillis=1000 -Dorg.gradle.jvmargs="-Xmx2048m -XX:MaxPermSize=1024m -XX:ReservedCodeCacheSize=440m -XX:+UseCompressedOops -XX:+HeapDumpOnOutOfMemoryError -Dfile.encoding=UTF-8" -Dorg.gradle.parallel=false -Dorg.gradle.daemon=false -Dorg.gradle.configureondemand=true'
          - ./gradlew clean assembleStageRelease appDistributionUploadStageRelease
Actually, it worked fine before.
But the building had been failing from last week.
Here is the error log.
> Task :app:lintVitalStageRelease FAILED
FAILURE: Build failed with an exception.
* What went wrong:
Execution failed for task ':app:lintVitalStageRelease'.
> Could not resolve all files for configuration ':app:lintClassPath'.
> Could not download groovy-all-2.4.15.jar (org.codehaus.groovy:groovy-all:2.4.15)
> Could not get resource 'https://jcenter.bintray.com/org/codehaus/groovy/groovy-all/2.4.15/groovy-all-2.4.15.jar'.
> Could not GET 'https://jcenter.bintray.com/org/codehaus/groovy/groovy-all/2.4.15/groovy-all-2.4.15.jar'.
> Connection reset
If I run the command on my local machine, it works fine now...
What problem??
I updated the `build.gradle`.
Before:
repositories {
    google()
    jcenter()
After:
repositories {
    google()
    mavenCentral()
    jcenter()
But it same results...
* What went wrong:
Execution failed for task ':spooncast:lintVitalStageRelease'.
> Could not resolve all files for configuration ':spooncast:lintClassPath'.
> Could not get resource 'https://repo.maven.apache.org/maven2/org/codehaus/groovy/groovy-all/2.4.15/groovy-all-2.4.15.jar'.
> Could not GET 'https://repo.maven.apache.org/maven2/org/codehaus/groovy/groovy-all/2.4.15/groovy-all-2.4.15.jar'.
> Connection reset
Theodora Boudale
December 17, 2021
Hi Aaron,
I just wanted to leave a note to say that I replied on Wednesday to the other post you created about this issue:
If you have any questions, please feel free to let me know in the other post or reach out via a support ticket.
Theodora
