In my switch from self-hosted stash to bitbucket, I encounter a new problem. I use Bitbucket to host a dozen of Puppet modules and I would love to set the same deployment key on all repos in this project.
Is it possible to do this without adding it manually in each repo ?
No, this is not currently possible in Bitbucket Cloud.
if you have a lot of repositories, a workaround could be to create a regular account for your puppet clients, put an SSH key onto that and then grant that account read access to your repos.
