automatically append JIRA issue ID into commit message
xion_admin July 7, 2017
I wonder whether it is possibel to automatically append the JIRA issue ID to every commit message automatically?
All our branch names include the issue id with the issue type name.
Is there a way to automatically append it to a commit message when commiting?
We are using script runner, maybe there is a way to do it with it?
Aron Gombas _Midori_
By the time the commit is created with the original commit message, it gets its hash. If you changed the commit message afterward (even programatically), that'd result in a new hash which could eventually break things.
So, I'd suggest you'd rather require committers to enter the issue key in the commit message (a'priori).
But this kind of thing get forgotten, it has to be done automatically.
Maybe via a commit pre hook? Any idea how to do this?
What version control system are you using?
xion_admin July 11, 2017
Bitbucket with git
Now that I know the environment, I added a new answer.
Adrien Horgnies
March 13, 2018
You can use the git prepare-commit-msg hook. It's a script that get executed before you write the commit message. I've written such a script. It works for branches named such as "feature/ABC-123-description" and will add "ABC-123" to the commit message. And the developer has all the liability to modify the commit message afterwards. You can set up such a hook at repository level or globally on a machine. That means you must set up the script on every developer machine though.
#!/bin/bash
# get current branch
branchName=`git rev-parse --abbrev-ref HEAD`
# search jira issue id in a pattern such a "feature/ABC-123-description"
jiraId=$(echo $branchName | sed -nr 's,[a-z]+/([A-Z]+-[0-9]+)-.+,\1,p')
# only prepare commit message if pattern matched and jiraId was found
if [[ ! -z $jiraId ]]; then
# $1 is the name of the file containing the commit message
sed -i.bak -e "1s/^/\n\n$jiraId\n/" $1
fi
Like • 15 people like this
rubens21
August 22, 2020
Thank you so much, Adrien!
Just a small improvement.
Since the project code may have numbers, I used `[A-Z0-9]` instead of `[A-Z]` to match the project code.
jiraId=$(echo $branchName | sed -nr 's,[a-z]+/([A-Z0-9]+-[0-9]+)-.+,\1,p')
Lefthandmedia
January 25, 2022 edited
I'm getting an error in source tree when using this pre-commit hook.
the file SED tries to open IS present and the comment is there.
git -c diff.mnemonicprefix=false -c core.quotepath=false --no-optional-locks commit -q -F C:\Users\Ralph\AppData\Local\Temp\ppjj2kg3.xax
sed: no input files
 on Windows10  , GIT2.30.2 Sourcetree 3.4.7
Brian Khuu
November 16, 2022
Thanks Adrien! Aside from forgetting to switch from #!/bin/sh to #!/bin/bash I was able to get your hook going. I've also added a bit of a change to also extract the jira ticket title as well, which may be of interest to some people here as well.
I also adopted rubens21's suggestion as well.
#!/bin/bash
COMMIT_MSG_FILE=$1
COMMIT_SOURCE=$2
SHA1=$3
## Automatically append jira issue ticket to every commit
## Ref: https://community.atlassian.com/t5/Bitbucket-questions/automatically-append-JIRA-issue-ID-into-commit-message/qaq-p/605991
# search jira issue id and title in a pattern such a "feature/ABC-123-description"
jiraId=$(echo $branchName| sed -nr 's,[a-z]+/([A-Z0-9]+-[0-9]+)-.+,\1,p')
jiraTitle=$(echo $branchName| sed -nr 's,[a-z]+/[A-Z0-9]+-[0-9]+-(.+),\1,p' | sed 's/-/ /g')
sed -i.bak -e "1s/^/\n\n\[$jiraId\] \: $jiraTitle\n/"$1
fi
Milind Shakya
January 9, 2019
I created a precommit hook that automatically prepends jira ticket id to your commits, if your branch has the ticket info. Works fine so far.
https://github.com/milin/giticket
Phill Pafford
October 11, 2023 edited
updated to work on OSX and Linux and only add the Jira Ticket, not the Jira Title
Gist here: https://gist.github.com/phillpafford/02437d61a90a8d5f8cd520944a7b618c
#!/usr/bin/env bash
set -e
BRANCH_NAME=$(git rev-parse --abbrev-ref HEAD 2>/dev/null)
JIRA_ISSUE=$(echo $BRANCH_NAME| sed -nr 's,[a-z]+/([A-Z0-9]+-[0-9]+)-.+,\1,p')
# only prepare commit message if pattern matched and JIRA_ISSUE was found
if [[ ! -z $JIRA_ISSUE ]]; then
## OSX and Linux compatable
sed -i '' -e "1s/$/\n\n\[$JIRA_ISSUE\]/" $1
fi
Commit Policy is an add-on for Bitbucket that enforces this via a custom hook.
See the full documentation here.
xion_admin July 11, 2017 edited
does it enforce that the user to insert the issue ID in the commit message?
Or does it automatically append the issue ID into the commit?
The later is prefered.
xion_admin July 25, 2017
I finally used following script:
http://monksealsoftware.com/add-jira-issue-number-to-git-commit-message/
to solve my problem
Max August 24, 2018
Any chance to re-upload it? it's 404 :(
