I'm building a pipeline yaml in Visual Studio and it reports at error on this line of code in the "variables" section
CAPABILITIES: [ 'CAPABILITY_NAMED_IAM' ]
Error: Incorrect type. Expected "string".
The pipeline works but Visual Studio reporting it as an error. I checked if there was any updates to any Atlassian Extensions but found none.
Hello @Sam Ware and thank you for reaching out to Community!
I suspect that Visual Studio might be trying to validate the YML code with the standard YML syntax, but since pipes are a bitbucket pipelines feature, it might be getting confused with the pipe's syntax.
In this case, in order to check your YML file for any syntax error I would suggest using Atlassian own Validator for bitbucket-pipelines.yml , as this will execute the same checks as when your build is triggered.
Thank you, @Sam Ware !
Patrik S
From setup to deployment—this learning path shows you how to build your first app using Forge. Learn the essentials, streamline workflows, and bring custom solutions to life across Jira, Confluence, and more.
Start Learning
