aws-code-deploy: S3 location and command
AZZ February 22, 2023
a few questions
how can I specify a location (path) on a bucket where I'd like to deploy the artifacts?
As of right now, it appears that S3_BUCKET only takes the bucket name e.g. s3://mybucket
"Command":
 is there a way to combine both actions ( "upload" and "deploy") without invoking the pipe twice?
Thank you.
ref: https://bitbucket.org/atlassian/aws-code-deploy/src/master/README.md
Oleksandr Kyrdan
February 24, 2023
Hi @AZZ
Thank you for your question!
1) there is an example in the Readme for your case:
script:
  - pipe: atlassian/aws-code-deploy:1.1.1
    variables:
      AWS_DEFAULT_REGION: 'ap-southeast-2'
      AWS_ACCESS_KEY_ID: $AWS_ACCESS_KEY_ID
      AWS_SECRET_ACCESS_KEY: $AWS_SECRET_ACCESS_KEY
      COMMAND: 'deploy'
      APPLICATION_NAME: 'lambda-application'
      DEPLOYMENT_GROUP: 'my-deployment-group'
      WAIT: 'true'
      S3_BUCKET: 'my-bucket'
      VERSION_LABEL: 'lambda-app-1.0.0'
      BUNDLE_TYPE: 'YAML'
2) the pipe supports `upload` or `deploy` mode in the current implementation.
Best regards,
Oleksandr Kyrdan
AZZ February 24, 2023
@Oleksandr Kyrdan,
Thank you for the reply.
If I understood you correctly:
1.  there is no way to specify a path on the bucket? I was hoping to upload to a specific location e.g. "mybucket/deployments".
2. There is no option to upload and deploy in the same pipe call?
Oleksandr Kyrdan
February 24, 2023 edited
@AZZ
1. You could provide the FOLDER variable for the pipe to specify path on you S3 bucket according to the Readme documentation.
FOLDER If the deployable artifact is in any folder inside bucket, specify the folder name
2. You should choose only one of the option or upload or deploy at once.
Like • Steffen Opel _Utoolity_ likes this
AZZ February 27, 2023
worked like a charm. Thank you @Oleksandr Kyrdan
azam pasha May 7, 2025
  • Using pipe: atlassian/aws-code-deploy:1.6.0 with FOLDER and S3_BUCKET options.
  • Artifact uploads correctly to the specified S3 path and triggers a deployment in AWS CodeDeploy.
  • However, the uploaded file has a MIME type of binary/octet-stream instead of application/zip.
  • This causes the artifact to not be recognized as a zip file when downloaded from S3.
can you please help here
