aws-codedeploy integration
amrsalah944 July 14, 2022
The BUNDLE_TYPE option is not working, I passed it tar, but when bitbucket calls codedeploy it pass it as zip
There is a bug in the pipe.py file, That if statement is wrong
if self.get_variable('BUNDLE_TYPE') in ['zip', 'tar', 'tgz']:
deploy_parameters.update({'fileExistsBehavior': self.get_variable('FILE_EXISTS_BEHAVIOR')})
https://bitbucket.org/atlassian/aws-code-deploy/src/master/
Oleksandr Kyrdan
July 15, 2022
Hi @amrsalah944
Thank you for your question!
It would be nice if you provide us your bitbucket-pipelines configuration to investigate the issue you reported.
Best regards,
Oleksandr Kyrdan
amrsalah944 July 17, 2022 edited
Thanks for your reply!
my pipeline file is as below
pipelines:
branches:
dev:
- step:
deployment: test
script:
- pipe: atlassian/slack-notify:2.0.0
variables:
WEBHOOK_URL: $SLACK_WEBHOOK_URL
MESSAGE: 'Deployment to CRM-DEV initiated. All others will be paused until deployment complete.'
- tar -cf application.tar .
- pipe: atlassian/aws-code-deploy:0.2.5
variables:
BUNDLE_TYPE: "tar"
AWS_DEFAULT_REGION: $AWS_DEFAULT_REGION
AWS_ACCESS_KEY_ID: $AWS_ACCESS_KEY_ID
AWS_SECRET_ACCESS_KEY: $AWS_SECRET_ACCESS_KEY
APPLICATION_NAME: $APPLICATION_NAME_DEV
S3_BUCKET: $S3_BUCKET_DEV
COMMAND: 'upload'
ZIP_FILE: 'application.tar'
region: us-east-2
DEBUG: 'true'
variables:
BUNDLE_TYPE: "tar"
DEPLOYMENT_GROUP: $DEPLOYMENT_GROUP_DEV
COMMAND: 'deploy'
WAIT: 'true'
region: us-east-2
IGNORE_APPLICATION_STOP_FAILURES: 'true'
FILE_EXISTS_BEHAVIOR: 'OVERWRITE'
DEBUG: 'true'
variables:
MESSAGE: 'Deployment to CRM-DEV is live.'
even the var is exported, but the aws command end like that
--env=BUNDLE_TYPE="tar" \
++ aws deploy create-deployment --application-name web-dev --deployment-group CodeDeploy1 --revision 'revisionType=S3,s3Location={bucket=xxx-web-dev,bundleType=zip,key=web-dev-xxx}' --ignore-application-stop-failures --file-exists-behavior OVERWRITE
Oleksandr Kyrdan
October 6, 2022
Hi @amrsalah944
Looks like you try to use outdated (0.2.5) pipe's version with a new (1.1.1) parameters:
Currently the latest pipe's version is 1.1.1:
script:
  - pipe: atlassian/aws-code-deploy:1.1.1
    variables:
      COMMAND: 'upload'
      APPLICATION_NAME: 'my-application'
      ZIP_FILE: 'myapp.zip'
Support for variable BUNDLE_TYPE has started since version 0.3.0. And it's always good idea to update the pipe to the latest version that includes new features, fixes, upgrades.
Best regards,
Oleksandr
