×Hello
I've been trying to run my pipeline with this yml configuration file but i keep getting this problem
bash: apt-get: command not found
This is the yml
image: ruby:3.0.3
pipelines:
default:
- step:
name: Run minitests
script:
# Dependencias necesarias
- apt-get update && \
apt-get install -y \
fonts-liberation \
libasound2 \
libatk-bridge2.0-0 \
libatk1.0-0 \
libatspi2.0-0 \
libcups2 \
libdbus-1-3 \
libdrm2 \
libgbm1 \
libgtk-3-0 \
libnspr4 \
libnss3 \
libu2f-udev \
libvulkan1 \
libxcomposite1 \
libxdamage1 \
libxfixes3 \
libxkbcommon0 \
libxrandr2 \
xdg-utils && \
rm -rf /var/lib/apt/lists/*
# Configuracion de chrome y chromedriver
- dpkg -i driver/117.0.5938.132/google-chrome.deb
- export CHROMEDRIVER_PATH=driver/117.0.5938.132/
- export PATH="${CHROMEDRIVER_PATH}:${PATH}"
- export BROWSER=:chrome
- export LOAD=eager
- gem install bundler
- bundle install
- rake runner:run_tests
It's the image im using? i used the same image in a docker with the same steps and everything runs fine, i don't understand why this happens in the pipeline
Hi @Cesar Alejandro Chavana Cazarez ,
The issue is the '\' this are used for escaping in the shell. You can remove it and it should work.
