I have a react site which i want to build and deploy using bitbucket pipelines. my pipeline runs and deploys the content of the dist folder in what seems to be correct manner. the correct files appear on my azure storage. however when i try opening the site I get the following error:
Failed to load module script: Expected a JavaScript module script but the server responded with a MIME type of "application/octet-stream". Strict MIME type checking is enforced for module scripts per HTML spec.
I am using yarn and vite.
@sschroders hi. New version azure-storage-deploy:2.4.0 released, which will automatically guess the content-type of files.
Please, provide feedback if this version solved your problem.
Regards, Igor
Edit after some digging I found out the problem is with the deploy as it deploys everything with the wrong content type (application/octet-stream) I am using atlassian/azure-storage-deploy:2.2.1 pipe to deploy.
@sschroders hi. Azure automatically set the default application/octet-stream content type. I will try to provide a solution for this case in future releases.
Regards, Igor
Learn why Compass was built to tackle dev experience at scale. See how Atlassian uses it to boost visibility, reduce cognitive load, and drive consistency—plus tips to get started and customize your IDP for stronger team engagement.
Join the webinar ✨Online forums and learning are now in one easy-to-use experience.
