bitbucket pipelines skipping upload for existing cache
wade May 14, 2025 edited
yml
doc: https://support.atlassian.com/bitbucket-cloud/docs/cache-dependencies/#Caching-with-file-based-cache-keys
I want to update project_cache when Cargo.lock content changes. However, cache updates are skipped.
how to fix?
Syahrul
May 18, 2025
G'day, @wade
Welcome to the community!
I think there's a misunderstanding. With Cache keys, changes made in the pipeline build will not invalidate the existing cache. Therefore, what you're observing is expected behavior; the cache will only be invalidated if the changes were made via a commit.
Custom caches can support file-based cache keys. File-based cache keys allow for the generation and restoration of caches based on a set of files. Any changes to those files would result in a new cache.
Basically, changes to the files, in this case Cargo.lock, through commit will then trigger a new cache to be uploaded.
I hope this helps.
Syahrul
wade May 18, 2025
yes.
thanks.
atlassian, forge, forge learning path, atlassian learning, cloud app development, forge app development, build forge apps, atlassian certification, developer training, jira app development, confluence app development, automation, ui frameworks
Turn Ideas into Atlassian Apps 📱
From setup to deployment—this learning path shows you how to build your first app using Forge. Learn the essentials, streamline workflows, and bring custom solutions to life across Jira, Confluence, and more.
Start Learning
