bitbucket repository has vanished
Chris Hutchinson
I have (had) a repository at https://OurOrg@bitbucket.org/ourdev/icmcom.git but this has vanished from the bitbucket UI and all other repos in that https://OurOrg@bitbucket.org/ourdev/ location are gone.
I can see some expected repos at https://OurOrg@bitbucket.org/ such as https://OurOrg@bitbucket.org/xyz, but repositories located under the path 'ourdev' are  gone.
Is there any way to find these missing repos?
Ben
February 12, 2024
Hi Chris,
The location you've mentioned refers to a personal workspace, this personal workspace does not have the username you have mentioned present as a member, therefore you can't authenticate using username@bitbucket.org.
I would suggest double checking your remote locations with the following command for the true repository location:
  • git remote -vvv
Cheers!
- Ben (Bitbucket Cloud Support)
