bitbucket self hosted runner fails after successful execution
jgaleano
January 30, 2024
Hi, community,
I have a pipeline with which I am trying to run the automated tests of my API suite, using the runner to run self-hosted on Windows and be able to establish a local connection with the services and databases
When I run my tests locally they all pass and the execution is successful, but in the pipeline, the execution is failing despite not having tests with errors.
The tests I am running are using maven, java, rest assured, testng.
This is the part of the pipeline that is being executed
Where P refers to the profile in maven and -Denv is an environment variable that refers to the environment
image: maven:3.6.3
pipelines:
custom: api:
- step: runs-on:
- self.hosted
- windows
name: APIs Regression
caches:
- maven script:
- mvn clean test -P$Profile -Denv=$Environment
artifacts:
- allure-results/**
- reports/**
This is part of the runner's logs
Test report processing complete.
Updating step progress to COMPLETING_LOGS.
Appending log line to main log.
Shutting down log uploader.
Tearing down directories.
Cancelling timeout
Completing step with result Result{status=FAILED, error=None}.
Setting runner state to not executing step.
Waiting for next step.
Finished executing step.
Boris Alyurov March 10, 2025 edited
What was the resolution to this? I am having a similar issue with our local runner 3.16.0.
Mark C
January 31, 2024
Hi @jgaleano,
Welcome to the community.
Would it be possible for you to try to re-create your Windows runners and see if it still fails?
Let me know how it goes.
Mark C
jgaleano
March 5, 2024 edited
Hi @Mark C ,
Thanks for your reply.
The runner was configured again from 0 and I still have the same problem, the tests run without problem, and even without error the pipeline is failing, and in the runner console you can see "Completing step with result Result{status=FAILED, error=None}"
Julián G.
Like Sabine Mayer likes this
Mark C
March 6, 2024
Hi @jgaleano
I'd suggest checking the Windows self-hosted runners logs and see if there are specific error messages that may explain why there are no logs presented on Bitbucket Cloud Pipelines UI.
Could you also ensure that your runner's version is up to date?
You can refer to this documentation on Troubleshooting runners.
Mark C
atlassian, compass, developer experience, devex, platform engineering, internal developer platform, component catalog, atlassian learning, productivity tools, developer productivity, software architecture, compass webinar, engineering teams
Discover how Compass drives DevEx and productivity at Atlassian 🏃🏻‍♂️
Learn why Compass was built to tackle dev experience at scale. See how Atlassian uses it to boost visibility, reduce cognitive load, and drive consistency—plus tips to get started and customize your IDP for stronger team engagement.
Join the webinar ✨
