I want to run some script over multiple azure VM's. Is there any way to do this by PIPE azure-vm-linux-script-deploy or any other way around?
Hi, @Ankit Jangid !
Thanks for the question. Azure deploy pipe is working right now for one VM only.
Actually, this is a great idea for custom pipe! See how easily to writing custom pipes at https://bitbucket.org/blog/build-flexible-ci-cd-pipelines-with-custom-pipes
From setup to deployment—this learning path shows you how to build your first app using Forge. Learn the essentials, streamline workflows, and bring custom solutions to life across Jira, Confluence, and more.
Start Learning
