curl example of adding a permission group to a repository
Len Esterhuyse January 19, 2023
Detailed example of adding a permission group to a repository with curl?
Theodora Boudale
January 20, 2023
Hi @Len Esterhuyse,
You can use the following endpoint:
https://developer.atlassian.com/cloud/bitbucket/rest/api-group-repositories/#api-repositories-workspace-repo-slug-permissions-config-groups-group-slug-put
An example with curl is as follows:
curl -u BitbucketUsername:AppPassword -X PUT -H "Content-Type: application/json" https://api.bitbucket.org/2.0/repositories/<workspace-id>/<repo-slug>/permissions-config/groups/developers -d '{"permission": "write"}'
where
BitbucketUsername is the username of a Bitbucket account with admin permissions to the repo
AppPassword is an app password for this account
<workspace-id> replace with the workspace id where the repo belongs
<repo-slug> replace with your repository slug
developers replace with the group slug of the group you want to add
write is the permission you want to give, it can also be 'read' or 'admin'
If the group already has access to the repo, the group permission will be changed to what you set in this call. Otherwise, the group will be added to the repo with the permissions you set in the call.
Theodora
Len Esterhuyse January 22, 2023 edited
Thank you very much for the example @Theodora Boudale
Tweak a bit by escaping last bit  to :
 -d "{\"permission\": \"write\"}"
atlassian, forge, forge learning path, atlassian learning, cloud app development, forge app development, build forge apps, atlassian certification, developer training, jira app development, confluence app development, automation, ui frameworks
Turn Ideas into Atlassian Apps 📱
From setup to deployment—this learning path shows you how to build your first app using Forge. Learn the essentials, streamline workflows, and bring custom solutions to life across Jira, Confluence, and more.
Start Learning
