`%d` Day output from build duration for atlassian/bitbucket-build-statistics:0.2.0
yysaki
December 23, 2020 edited
Hello.
Bitbucket Cloud is useful and helpful for my work.
https://jira.atlassian.com/browse/BCLOUD-13637?error=consent_required&error_description=Consent+required&state=9086f647-509f-4ce2-8991-7e5674189e00
I found out about this pipe from the URL above and tried to run it like this:
script:
- pipe: atlassian/bitbucket-build-statistics:0.2.0
variables:
BITBUCKET_USERNAME: $BITBUCKET_USERNAME
BITBUCKET_APP_PASSWORD: $BITBUCKET_APP_PASSWORD
And I got the following like statistics:
| Bitbucket build statistics |
| Repository | Builds | Build Duration |
| my-company/my-project | 39 | 02:50:46 |
| my-company/other-project | 0 | 00:00:00 |
| .... | 0 | 00:00:00 |
✔ Success!
I had one problem with this one. The pipe outputs the build duration time with the format of `'%H:%M:%S'`, not minutes. The build duration time for the last 30 days in my repository took about 1610 minutes (calculated based on the CLI at https://github.com/atlassian/build-stats), but at this time it shows `02:50:46` using this pipe. It's format looks like that day `%d` output is missing.
I'd like to know the build duration time for each repository without missing anything, so do you have any plan to add the day output to the format, or unifying the display format with minutes?
Halyna Berezovska
January 21, 2021
@yysaki hello! Check out new version 0.2.1 and see if it is fine for you.
Cheers, Galyna
atlassian, jira product discovery learning path, product discovery training, idea prioritization, align stakeholders, discovery to delivery, product collaboration, atlassian learning, dev process, roadmap planning, insight capture, team alignment
Elevate Your Skills with Jira Product Discovery!
Unlock your potential and learn how to use Jira Product Discovery to your advantage. You’ll have the expertise to revolutionize ideas and insights, roadmapping, engage and align teams and stakeholders, and deliver the best solutions—faster. Enroll today!
Start Learning
