define and calling stage using yaml anchors
Prashantanu Singh Rathore (Temp) April 14, 2023
Is it possible to define a stage under definations and call like steps. ?
https://support.atlassian.com/bitbucket-cloud/docs/yaml-anchors/
Mark C
April 16, 2023
Hi @Prashantanu Singh Rathore (Temp),
Thank you for reaching out to the community.
Indeed, it is possible to use stages as anchors.
Here's an example way to do it as mentioned in this other community post:
definitions:
  steps:
    - step: &just-a-step
        name: Do the thing
        script:
          - echo 'Doing the thing'
  stages:
    - stage: &my-awesome-stage
        name: My awesome stage
        steps:
          - step: *just-a-step
pipelines:
  branches:
    master:
      - stage: *my-awesome-stage
Hope it helps and let me know how it goes.
Mark C
Prashantanu Singh Rathore (Temp) April 17, 2023
Thanks its working. I tried for paraller step exuection inside an stage. But it failed. Please verify the following config
stages:
   - stage: &continuous-integration-pipeline
        steps:
           - step: *Install-Dependencies
            - parallel:
                   - step: *Unit-Test
                   - step: *E2E-Test
                   - step: *Build
Okay. this link says stage does not parallel steps.
https://support.atlassian.com/bitbucket-cloud/docs/stage-options/
