I'm deploying my dockerized Django app using bitbucket pipelines but unfortunately, the pipeline already creates two containers but not the last one the error and my files are attached below.
error:
ERROR: for db Cannot create container for service db: authorization denied by plugin pipelines: -v only supports $BITBUCKET_CLONE_DIR and its subdirectories
Encountered errors while bringing up the project.
docker-compose.yml
version: "3.8"
services:
db:
container_name: db
image: "postgres"
restart: always
volumes:
- postgres-data:/var/lib/postgresql/data/
app:
container_name: app
build:
context: .
restart: always
volumes:
- static-data:/vol/web
depends_on:
- db
proxy:
container_name: proxy
build:
context: ./proxy
restart: always
depends_on:
- app
ports:
- 80:8000
volumes:
- static-data:/vol/static
volumes:
postgres-data:
static-data:
bitbucket-pipelines.yml
image: python:3.7.2
pipelines:
default:
- step:
services:
- docker
caches:
- docker
- pip
script:
- pip install docker-compose
- docker-compose -f docker-compose-deploy.yml up --build
- pipe: atlassian/aws-code-deploy:0.2.5
variables:
AWS_DEFAULT_REGION: $AWS_DEFAULT_REGION
AWS_ACCESS_KEY_ID: $AWS_ACCESS_KEY_ID
AWS_SECRET_ACCESS_KEY: $AWS_SECRET_ACCESS_KEY
COMMAND: 'upload'
APPLICATION_NAME: $APPLICATION_NAME
ZIP_FILE: 'application.zip'
S3_BUCKET: $S3_BUCKET
VERSION_LABEL: 'my-app-2.0.0'
variables:
COMMAND: 'deploy'
DEPLOYMENT_GROUP: $DEPLOYMENT_GROUP
WAIT: 'true'
IGNORE_APPLICATION_STOP_FAILURES: 'true'
FILE_EXISTS_BEHAVIOR: 'OVERWRITE'
definitions:
services:
docker:
memory: 3072
Hi @Zain Khan and welcome to the community!
Based on the error message and the files you included here, I believe the error is caused by the path where you are mounting the volumes. At the moment, we don't support mapping volumes outside of $BITBUCKET_CLONE_DIR:
We've had to restrict a few for security reasons, including Docker swarm-related commands, docker run --privileged, docker run --mount, and mapping volumes with a source outside $BITBUCKET_CLONE_DIR.
Volumes will need to be mounted inside $BITBUCKET_CLONE_DIR (/opt/atlassian/bitbucketci/agent/build/.* or /opt/atlassian/pipelines/agent/build/.*)
Theodora
