'git' not found in pipeline
Daeyeon Joo
March 8, 2019
I have working pipeline configuration and it is working for many projects.
But today I have created new one and configured like below:
image: node:9.11.1-alpine
options:
docker: true
pipelines:
branches:
develop:
- step:
caches:
- node
script: # Modify the commands below to build your repository.
# You must commit the Gradle wrapper to your repository
# https://docs.gradle.org/current/userguide/gradle_wrapper.html
- apt-get update && apt-get install -y unzip git
- export TAG=$(git tag --contains $BITBUCKET_COMMIT)
But It seed to be not working.
export TAG=$(git tag --contains $BITBUCKET_COMMIT)/opt/atlassian/pipelines/agent/tmp/shellScript1396312809883348351.sh: line 4: git: not found
What is the problem?
Please let me know :)
davina
April 16, 2019
Hi @Daeyeon Joo
Since you are using an alpine image, you need to use the appropriate commands.
Try
apk update && apk add git
or
apk update && apk upgrade && apk add --no-cache git
If you don't need to use an alpine image you can also switch to using the default pipelines image which has node and git already installed.
Hope this helps!
atlassian, forge, forge learning path, atlassian learning, cloud app development, forge app development, build forge apps, atlassian certification, developer training, jira app development, confluence app development, automation, ui frameworks
Turn Ideas into Atlassian Apps 📱
From setup to deployment—this learning path shows you how to build your first app using Forge. Learn the essentials, streamline workflows, and bring custom solutions to life across Jira, Confluence, and more.
Start Learning
