git push origin not working
kostik_noir August 6, 2013
Hi.
Basically I have same difficulty like at
https://answers.atlassian.com/questions/67729/git-push-origin-not-working
I commit, push but I not see updates at Bitbucket.
My repository is private and only 2 BitBucket accounts have access there:
*) me - owner
*) other account in read-only mode
Thanks in advance.
Best regards, Konstantin
m
August 6, 2013
Konstantin,
You don't say what kind of response your client returns you when you push. Is the push failing or does it appear to succeed? It is a good idea to paste the response here.
Your first step is to see which remote your configuration is set to push to. You can do this with this command:
git remote origin
If you are on HG, you can list the contents of .hg/hgrc in your local repo to see the remotes.
kostik_noir August 7, 2013
By the way - I can't to delete my "answer"
Hi. Thanks for the quick reply.
To be consistent:
Win 8 x64
client: msysgit
client response:
$ git push origin master
Everything up-to-date
It was not the first push to this repository and before that everything was fine.
$ git log
I see my last commits but I have not seen same commits at BitBucket
After
$ git checkout master
I lost all updates which I made before but, fortunately, I made backup of files.
So now I restored last state of files in repository (but without history).
And now I'm more interested why this occurred.
m
August 7, 2013
Konstantin,
So, it appears you made some changes but did not add them to the staging area. So, the process is this:
  1. Add or edit a file in your repository.
  2. Stage the file with this command:
    git add myfile.txt
  3. Repeat until are your changes are made.
  4. Commit all changes in staging with this command:
    git commit -m "message"
  5. Push your changes:
kostik_noir August 12, 2013
>git add myfile.txt
Yes, I know about this sequence.
And as I wrote
> $ git log
kostik_noir August 13, 2013
Closed
To be consistent:
Win 8 x64
client: msysgit
client response:
$ git log
After
