how to add node typescript project deploy in heroku.
Arun kumar gupta
August 24, 2021
# Template NodeJS build
# This template allows you to validate your NodeJS code.
# The workflow allows running tests and code linting on the default branch.
image: node:10.15.3
pipelines:
default:
- parallel:
- step:
name: Build and Test
caches:
- node
script:
- npm install
- npm test
- step:
script:
- npm install eslint
- npx eslint .
caches:
- node
- step:
deployment: production
script:
- pipe: atlassian/heroku-deploy:1.2.1
variables:
HEROKU_API_KEY: $HEROKU_API_KEY
HEROKU_APP_NAME: $HEROKU_APP_ANME
ZIP_FILE: $HEROKU_APP_ZIP_FILE
Here is my code how to deploy it. all time I get error.
Oleksandr Kyrdan
August 27, 2021
Hi @Arun kumar gupta
Thank you for your question!
Provide us with more details about your errors (logs, setup configuration), please, to help you.
Best regards,
Oleksandr Kyrdan
atlassian, forge, forge learning path, atlassian learning, cloud app development, forge app development, build forge apps, atlassian certification, developer training, jira app development, confluence app development, automation, ui frameworks
Turn Ideas into Atlassian Apps 📱
From setup to deployment—this learning path shows you how to build your first app using Forge. Learn the essentials, streamline workflows, and bring custom solutions to life across Jira, Confluence, and more.
Start Learning
