git -c diff.mnemonicprefix=false -c core.quotepath=false --no-optional-locks push -v --tags --set-upstream poligonosdemos poligonosapp-play-billing:poligonosapp-play-billing
Pushing to https://bitbucket.org/poligonosapp/poligonosdemos.git
Uploading LFS objects: 78% (300/384), 2.0 MB | 0 B/s, done.
Unable to find source for object ae576713bc196098f7438dede6ff1f835a23291c32b745ad7e6fb6db809a719b (try running git lfs fetch --all)
error: failed to push some refs to 'https://bitbucket.org/poligonosapp/poligonosdemos.git'
Completed with errors, see above.
Learn why Compass was built to tackle dev experience at scale. See how Atlassian uses it to boost visibility, reduce cognitive load, and drive consistency—plus tips to get started and customize your IDP for stronger team engagement.
Join the webinar ✨Online forums and learning are now in one easy-to-use experience.
